"jump" start computer, without power switch
Discussion in 'Tech Support' started by gEnEsis_AiX, 20 Apr 2006.
  1. gEnEsis_AiX
    gEnEsis_AiX What's a Dremel?
    14 Feb 2006
    i just put togheter my computer, far away from my case, and i got no power on button. is there a way, to "jump"start the mainboard?
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Find the pins on the motherboard that the power switch connects to, and connect them. I like to use the tip of a knife, but a jumper or a screwdriver'll also work quite well.
    They'll probably be labelled "pwr sw", but check your manual :)
  3. gEnEsis_AiX
    14 Feb 2006
    yes, i hoped that it was that way, the same as jumpstarting a psu. but its the pwr and ground?
  4. gEnEsis_AiX
    14 Feb 2006
    is there a lot of voltage/amps on the pins?
  5. gEnEsis_AiX
    14 Feb 2006
    jumpstarted :D
  6. LogicalJester
    LogicalJester What's a Dremel?
    8 Dec 2005
    About 640,000,000 volts and 2 amps, so get a very long stick and stand well back... :idea:
  7. McKaamos
    McKaamos What's a Dremel?
    12 Feb 2006
    at most 5 volts at 0.something miliamps.
    safe to start with a piece of metal, but i'd reccomend a philips screwdriver for it.
  8. chemo
    chemo True Jungle Brother
    20 Feb 2005
    sorry to revive an old thread but is this possible without doing any damage to the motherboard? or is there a risk of sparks flying and it going into melt down?
  9. fev
    fev Industry Fallout
    13 Aug 2003
    doesn't do it any harm at all, the way i boot my RM server box is the two wires that should be on the power button, just spark them
    disconnected the button so mother couldn't poke it
  10. chemo
    20 Feb 2005
    eww, dont like the sounds of sparks :jawdrop: ill try to find a switch from a case somewhere
  11. fev
    13 Aug 2003
    it's not an actual spark, it's a term of phrase.... used totally wrong in this situation i guess haha
  12. chemo
    20 Feb 2005
    oh right, so its pretty safe to do it then
  13. hitman012
    hitman012 Minimodder
    6 May 2005
    It'll work fine as long as you short the correct pins. The currents and voltages involved are just signal-level (in the tens of milliamps), so it won't be an issue.
  14. chemo
    20 Feb 2005
    ahh ok then, cheers guys :)
  15. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    Probably less than 10 mA. I use a phillips most of the time if Im testing.
  16. speedy187
    speedy187 What's a Dremel?
    30 Oct 2008
    HI,
    nEED a bit of help here, iv connected/short the correct pins and my pc starts and then turns off after 4-7 sec :jawdrop:........any 1 have any ideas y this happens??????
    any help will be great :confused:
  17. ElThomsono
    18 Mar 2005
    Don't keep them connected, the power switch just connects them for a quarter of a second.
    Touch them, it'll start up, and then immediately disconnect them :)
  18. speedy187
    30 Oct 2008
    thanks for the reply, yep thats wat iv been doing and still it turns off after 4-6 secs any ideas wat could be causing this :(
  19. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    could be lots of things. First off, welcome to the forums, second, good job at using the search function!
    There could be lots of reasons, lets start at the beginning though. What do you have for a system, list all the hardware thats in it.
    Once you list that, why are you trying to start it this way?
    Is this a brand new build? old one that isn't working anymore? etc.
  20. speedy187
    30 Oct 2008
    its my old pc thats was working fine till the wires(led lights, power button, restart buttton etc) from the case got cut due to a mistake from me thinking it was only the wires for blue led lights and clock on the out side of the case on a open and close panel but now i dont have a power button to start my computer so i use a scewdriver to start it with the power pins which seemed to work till after 4-6 it turns off ....................my computer is intel 3.60 process.....2 gig of ddr ram...intel motherboard.....dvdrw....floppy.....etc
    The wires i cut where connected to a panel that opens (wen opend you see the dvdrw) and closes which broke off and was hanging for a year by the wires, so i had enough with the panel hanging down so i cut away the wiress which seem to be only the wires for the led lights and clock on the panel....how wrong was i....the wires run buck inside to the power and restart button....so now no power button
    how dumb i am..... :wallbash:
