Modding help : how to connect laptop disk to ide on a desktop ?
Discussion in 'Modding' started by byteman, 2 Dec 2005.
  1. byteman
    byteman What's a Dremel?
    14 May 2004
    i need to connect a notebook harddrive to a standart ide cable on a PC
    does anyone know the schemes for that ? :blush:
    thank you :worried:
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    There are schematics out there, but for ease and reliability you'd be better off buying one. You can get them off ebay for about £3, just serach for "IDE adapter"
    Something like this.
  3. byteman
    14 May 2004
    thank you man!!! :cooldude:
  4. mattthegamer463
    26 Nov 2004
    this is basically the same question except backwards. is there a way to get a 3.5" IDE -->2.5" laptop IDE adapter? i want to use a desktop drive in a laptop im modding.
  5. BjD
    BjD What's a Dremel?
    10 Apr 2003
    @mattthegamer
    Ive never seen a convertor for that, but you could possibly fashion something yourself. Think the tricky bit is getting a male conector for the laptop end.
  6. ElThomsono
    18 Mar 2005
    It's not gonna fit.... :naughty:
    I don't know of one, but power would be an issue. You'd need a strong supply, my laptop draws only 10% what my desktop uses :rolleyes:
    You can definately do it as USB, those adapters come with an external power brick though.
  7. mattthegamer463
    26 Nov 2004
    yeah, i forgot about the power stuff. oh well, a external USB one would work fine.
  8. emj1s
    emj1s What's a Dremel?
    26 Jun 2004
  9. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
  10. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
  11. Drexial
    Drexial Minimodder
    28 Jul 2005
    that is an IDE, its just slim.
    Load Type Slot Load
    Interface IDE
    thats the same drive im getting for my mod project... look for my project soon on the log page..... just need to wait till i buy another dremel and a few other suplies.
  12. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Its still an ide meant for laptops, so its not the traditional 40-pin ide of big optical drives. I could be wrong but i have never seen a slim drive that was 40pin ide with no adaptor
  13. Firehed
    15 Feb 2004
    Nope, you're dead right. Just like how Serial and Parallel drives are both ATA (advanced transfer attachment, I think) drives, though PATA drives are referred to incorrectly as being IDE more commonly than actually being correctly called PATA (I think IDE is a generic term for 40/80wire cable-based connection). All slim optical drives have the mini-IDE connector (for lack of knowing a technical term, though that might be it).
    Logic Supply also has slim-optical ATA adaptors: http://www.logicsupply.com/product_info.php/cPath/47_69/products_id/108 (they have another one which is 44-pin, some special thing for a couple mini-ITX boards I think, but effectively what the slim hard drives have)
  14. nbfsoldier
    nbfsoldier What's a Dremel?
    27 Nov 2005
    if you have a spear computer lying around why not just share and grant access to change files to the whole hdd in windows and network them together?
  15. tm36usa
    21 Jan 2004
    Because windows networks are too slow and unreliable
