News Researchers develop all-optical 'transistor'
Discussion in 'Article Discussion' started by Gareth Halfacree, 5 Jul 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    "positioned in such a way that the gap between them is the same as the wavelength of the light"
    Surely this means you cant shrink each unit smaller than this gap.
    uv light goes to 10nm, not very small.
  3. Gareth Halfacree
    4 Dec 2007
    But gamma ray photons are 10 picometres, which is a damn sight smaller than we're ever going to get using electronic components.
  4. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    Graphene will be mainstream before this gets out the lab - that's how far off this tech is.
    Light beams are too fat right now a real optical cpu die would be massive compared to todays, it's interesting tech and I am interested to see how it develops, because there's lots of benefits to using light, they just need to work on making the beams smaller at same time.
  5. greigaitken
    26 Aug 2009
    "But gamma ray photons are 10 picometres"
    what would my case be made of to stop it killing me?
  6. Griffter
    Griffter What's a Dremel?
    1 Jun 2012
    do i see light at the end of the tunnel?
  7. Gareth Halfacree
    4 Dec 2007
    Lead. But no, seriously, there are plenty of wavelengths between gamma rays and UV that would be suitable. I was merely pointing out that photons go to significantly smaller wavelengths than UV.
  8. greigaitken
    26 Aug 2009
    Ok, i thought that after uv, the smaller you go, the more damage it does to you.
    If GH says it's safe that's good enough for me.
  9. Gareth Halfacree
    4 Dec 2007
    Worst case, you go full-on Bruce Banner.
  10. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Take care when overclocking, because you won't like me when i'm angry :worried:
    Tyinsar likes this.
  11. maverik-sg1
    18 Aug 2010
    I spat my drink reading this one....brilliant!! :)
  12. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    I always find it amusing whenever these physics tech articles appear. There's always a string of comments from people who think they're more knowledgeable than the scientists in question and it invariably goes along the lines of... "it won't work because......."
  13. lp rob1
    lp rob1 Modder
    14 Jun 2010
    But even so, why would you need a particularly small CPU die for this? In silicon microelectronics, the whole design is planar, so having a small CPU die is necessary to fit a large number of transistors in. But with light, little to no heat is produced, so the same circuit could be stacked on multiple layers. So even though in a single layer you might only have, say, 30% of the 'transistors' of a comparable silicon CPU, you would have many thousands of layers.
  14. ev1lm1nd666
    ev1lm1nd666 What's a Dremel?
    23 Apr 2009
    Plus with this new tech you could build cpu's in 3D, stacking layer upon layer. This could lead to CPU's that need no/very little in the way of active cooling while being lightyears (pun intended) ahead of anything we have today.Technology has advanced to the level where we can produce things on a molecular level, just imagine the gaming computer of 50 years from now.....
  15. Blackshark
    Blackshark What's a Dremel?
    13 Apr 2004
    Graphene is a red herring. Whilst a lot of money is being pushed by governments desperate not to be left out, there has been little real world CPU applicable advances.
  16. Alecto
    Alecto Minimodder
    20 Apr 2012
    And the gamma-ray deflecting mirrors at this scale would be made of what ?
  17. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Once again it does not have the be gamma. IE: :read:
    (I've always wanted to use that one :lol: )
  18. sub routine
    sub routine Archie Gemel
    27 Sep 2007
    Hold on chewy were gonna overclock the nuts off this.
  19. Corky42
    30 Oct 2012
    The wave length that springs to mind for me are X-rays as they are in commonly used already, and X-rays range from 0.01 to 10 nm
  20. themassau
    themassau What's a Dremel?
    23 Mar 2012
    don't forget that these gamma rays would be low power so it will not penetrate the chip walls. also there are only a few photons per mirror.
    if the frequency is higher than the penetration is less that why infra red is line of sight and wifi isn't.
    the dangerous gamma rays from a nuclear reactor are really high energy there are many at once.
