Build Advice Upgrade advice.
Discussion in 'Hardware' started by m0o0oeh, 10 Nov 2014.
  1. m0o0oeh
    m0o0oeh Minimodder
    20 Dec 2006
    TL;DR : Help? Which upgrade item is going to give me the most noticeable improvement in my pc?
    Budget:
    Something in the region of £150 - 200
    Main uses of intended build:
    Gaming/recording music and video.
    Parts required:
    Ideally looking for advice about a new processor, RAM, and monitor
    Previous build information (list details of parts):
    MSI A55M E33 FM2 motherboard, AMD Athlon X4 740, 8gb DDR3 1600MHz, Radeon HD7790, 1tb WD Green.
    Monitor resolution:
    No-name 15" monitor @ 800x600, with a max of 1024x768 (my HDTV is now in the lounge, so I rescued it from my brothers room.)
    Storage requirements:
    Current drive is ok, but considering other options for future.
    will you be overclocking: No
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers):
    Recycling current motherboard
    Extra information about desired system:
    Recycling motherboard, 7790, and storage, case etc.
    For some reason, Windows only recognises 4 of the 8gb RAM. So I figured on replacing both sticks to give it a bit more grunt. The rig is a little over a year old, and I feel it's slowing down, and it needs a kick up the ass. I realise that my budget is tight, and as the computer works just fine for now, the processor can wait a bit maybe until I've saved up a bit more. I'm desperate for a new monitor bigger than 15", and I do think more RAM will be of more benefit than the processor. I'm mainly interested in peoples opinions on whether to go APU or stay with a standard CPU. Also, if anyone has any recommendations for gear to look at in the Christmas sales, that'd be great.
  2. johnim40
    johnim40 Minimodder
    23 Apr 2009
    Hi a ssd will give a new lease of life to it
    Also what version of windows do you use you need a x64 to reconize the full 8gb
  3. Shirty
    18 Apr 1982
    +1 on the above.
    If it were me, I'd go for something like this and this.
    Definitely make sure you are running a 64-bit copy of Windows too, might be a good time to reinstall from scratch directly on to the SSD.
  4. m0o0oeh
    m0o0oeh Minimodder
    20 Dec 2006
    Running Win 7 (iirc its x64. Ultimate/Home Premium, I can never remember.) An SSD would help a great deal...
  5. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    New monitor without a doubt.
    Whilst the computer may be slow in the occasional game, you're always having to look at a crappy monitor what ever you're doing (i.e. surfing the web).
    You could get a pretty decent monitor for £150 to £200, it will be the best upgrade you've done for ages! :)
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    Upgrading the CPU would either be only a small upgrade or bust the budget severely.
    As for the Ram, don't worry about it, its still close enough to the top end.
    I'd agree with the suggestion of a new monitor, a 24" with an IPS panel from a decent brand can be had for under £150 these days, that way you can stop using that medieval eye torture device.
    http://www.ebuyer.com/616175-lg-24mb35pm-24-led-ips-dvi-monitor-24mb35pm
    Then throw in a ssd:
    http://www.ebuyer.com/655772-plextor-128gb-m6s-series-2-5inch-ssd-px-128m6s
    Would be like night and day.
