Build Advice £200 upgrade options?
Discussion in 'Hardware' started by james_p, 20 Jan 2015.
  1. james_p
    james_p What's a Dremel?
    18 Jan 2011
    Hi,
    I've been asked to upgrade a PC with a budget of about £200 for fairly standard non-gaming use.
    Budget: £200 (but I'm not sure if that much is necessary)
    Main uses of intended build: word/excel, streaming and media server
    Parts required: CPU, mobo and maybe RAM
    Previous build information (list details of parts):
    M4A78LT-M
    Phenom II X2 555 BE
    Corsair HX520
    2x 2GB 1600Mhz RAM
    Storage requirements: n/a - have SSD + HD
    Will you be overclocking: no
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): SATA 6GB/s, simply to get the best out of the SSD.
    Extra information about desired system:
    I'm torn between which cpu route to go down; FM2, AM1 or Pentium K
    For example:
    AMD A6-6400K
    AMD Athlon 5350, Kabini, Quad Core, AM1, 2.05GHz
    Any thoughts on this would be very welcome
    Tempted to pick up one of these so that it could sit on a desk as well
    Hyperion EV33B Cube MATX Case
    Thanks!
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Was it the x2 555 the one where you can unlock to a quad and then OC?
  3. james_p
    18 Jan 2011
    Yes, it was that one but unfortunately of the two I bought, this one didn't.
  4. james_p
    18 Jan 2011
    Anyone?
    I'm leaning towards the FM2 but it would be good for someone else to agree/disagree.
    It's not my money so I'm keen not to get this wrong. Thanks
  5. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    FM 2 is a great choice. Easily within budget and decent performance.
