Hi all I have a 1366 motherboard at the moment with a x5650 but looking on around i could get a duel cpu motherboard for £80 with 2 e5540s in i was thinking of swapping out the cpus for 2 x x5650 cpus and using that instead the motherboard is a INTEL S5500BC SOCKET LGA1366 DDR3 SERVER MOTHERBOARD https://ark.intel.com/products/36601/Intel-Server-Board-S5500BC so would this work with a standard atx power supply eg a corsair cx750 and standard ddr3 ram and a corsair 750d case i want to use as a game server eg ark survival evolved or would you have any suggestions Thankyou for your help John
CPU's are on the "list" on intel page, so they'd be OK. DDR3 ECC RAM - So not the normal desktop stuff. This thread suggests the bpard might fit in the 750d - http://forum.corsair.com/v3/showthread.php?t=122924 - its a 13" by 10.5" board - but the last post say Corsair don't guarantee it'll fit.. PSU - no idea sorry.
From what i've seen on the net quickly... http://www.techspot.com/community/topics/ssi-ceb-question-vs-atx-e-atx.174068/ says mounting holes are the same but that the case needs to accept a larger atx board so if your case supports e-atx then you're fine. https://en.wikipedia.org/wiki/Computer_form_factor be warned they have different processor mounting holes. sstill looking for psu info... connectors look the same... can't find a direct comparison yet!!
750w should be more than enough power and that CX 750 supports the correct EPS12V 8pin connector. However, it only has 8x PCIe headers and the 2nd CPU socket will restrict the use of large gfx card plugged directly into the board. hope this helps
If it's a server it doesn't need a GPU. (And it's dual when you're talking about two things, "duel" means a fight between two people)
Thanks for that guys i only need a display so big gpu needed (And it's dual when you're talking about two things, "duel" means a fight between two people) lol i knew i spelt it wrong I found the manual too which says i need 3.5a on the 5vsb to even power it and only the high end psus have that
yeah a big GPU will need to be mounted elsewhere there isn't the room to plug it direct onto that motherboard. could an external control like an Arduino with a relay linked separately solve your problem with the 3.5 amps?
