Watercooling Rigid Acrylic tubing
Discussion in 'Hardware' started by Tynecider, 21 Aug 2013.
  1. Tynecider
    Tynecider Since ZX81
    23 Jun 2009
    Anyone know what I should be looking for to fit the following:
    Koolance brass compression fittings 3/4"OD / 1/2"ID
    Or
    Koolance brass compression fittings 1/2"OD / 3/8"ID
    The obvious is to match the sizes, But are there any tricks or suggestions for fitting and possibly any products that some could suggest?
    Cheers!
  2. Big Elf
    23 Apr 2009
