Hey everyone , Just want to give all of you watercooling fanatics a small update from bitspower, They are announcing some nicely designed pump brackets, Here are some specs and pictures ,what do you think of this? 1. Has To Be Used in 120/140 Water Tank Mount Panel. 2. This new feature is compitable with all D5/MPC655/DDC/MCP355 And Fixed In It. 3. And you will be able to install it where ever users see fit(or find space) 4. High Durability Anodized Finished In Black Color. 5. RoHS Compliant. Color: Black. Quantity : 2PCS. Included: 1. Screws/Accessories x 1Set. 2. 2.5MM Hexagon Wrench x 1PCS. I have to say this looks realy nice designwise, Like usual bitspower does a great job on that.
Well pump mountings definitely need to be improved, but this is a hard mounting – and pump vibrations will reverberate through the case. Therefore it doesn’t offer any upgrade to my shoggy sandwich outside of convenience and aesthetics.
