Watercooling Question - Fittings Compatibility
Discussion in 'Hardware' started by LCrK, 20 Jun 2015.
  1. LCrK
    LCrK What's a Dremel?
    19 Jun 2015
    Hello,
    Thought I'd ask a quick question from those who know a lot more about some fittings I'm looking at for a water cooling build I'd like to start in the next couple of weeks. I'm going to be building a light gaming machine within an M-ITX chassis and due to my almost certain to be terrible skills at bending hard tubing, I thought it would be wise to buy fittings with the correct angles to create the loop I require within the case. I'll list the links below to the parts - will these work?
    Tubing - http://www.scan.co.uk/products/ek-hd-tube-12-16mm-500mm-(2-pcs)
    Fittings - http://www.scan.co.uk/products/ek-hdc-fitting-16mm-g1-4-red
    Fittings - http://www.scan.co.uk/products/ek-af-angled-90-g1-4-black
    I've never attempted a custom loop before and I'd like to ensure everything is A-OK before I purchase all the parts. I'd also like to use a pump/reservoir combo for convenience and was looking at this:
    http://www.scan.co.uk/products/ek-sbay-ddc-32-pwm-(incl-pump)
    Any thoughts on this particular item?
