Watercooling Rv02 / Ft02 Rad
Discussion in 'Hardware' started by lilgoth89, 25 Feb 2012.
  1. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    so i was looking around the great depth that is the internet for ideas to watercool my RV02
    the original plan was to mod a 560mm ( 140x4 ) rad to the base of my case,
    then i stumbled across this beast
    http://www.specialtech.co.uk/spshop...m-180mm-Triple-Radiator--Black-pid-15191.html
    triple 180mm rad :jawdrop:
    http://www2.picturepush.com/photo/a/6858100/1024/Anonymous/IMG-2857.jpg
    it may require a little modding but it looks really awesome :)
    only really usefull for the rv02 / ft02 and scratchbuilding currently
    hopefully this should kick start the 180mm fan market
    as the choice is silverstone / phobya exept the phobya looks like the same fan as the silverstone but with red blades
    figured id Share :lol:
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I've considered that, but the standard RV-02 has a solid-alu Drivecage that goes down to the fans. I'd have to Dremel it to death to even get it to fit.
  3. FifteeeCal
    FifteeeCal What's a Dremel?
    11 Jun 2011
    Better get Dremeling then :D
  4. .//TuNdRa
    12 Feb 2011
    I'd rather not tear my raven apart just yet. I'll wait till I've started to hit the limits of what I can cool using air alone with those AP181's.
  5. AoE
    AoE What's a Dremel?
    4 Oct 2011
    th 3x180 does fit though in the raven? I think you can remove the HDD cage some how?
  6. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    But the Raven and FT02 are designed to be air coolers, they're some of the best around for it! I'd suggest springing for a new case if you want to W/C it and selling the Raven on the marketplace.
  7. Tangster
    23 May 2009
    No, you'd have to break out the dremel.
  8. AoE
    4 Oct 2011
    2x180?
  9. .//TuNdRa
    12 Feb 2011
    Would fit. But the key issue is that you're adding another 30mm to the fan-height, which means you're cutting short the amount of space there is to route cables through those hand holes, and the amount of space you can use to fit GPUs.
  10. longweight
    7 May 2011
    This.
  11. Tangster
    23 May 2009
    If I'm looking at my case properly, the far screw holes on the 180's are actually under the motherboard tray. I'm not sure how you'd fit the thing in directly over the 180's.
    This is how I've got mine setup, as you can see having a triple rad would mean it'd be difficult to get certain cards in. Wiring the 24pin was a nightmare, although it'd probably be easier without push pull(which I deemed necessary because the AP's have weak static pressure).
  12. .//TuNdRa
    12 Feb 2011
    You have to pull the default fan-mounts out to fit the radiator properly. To be honest; if I was cooling this thing internally; I'd rip the AP181's out and use Phobya Nano 180mms anyway.
  13. bnicholls195
    bnicholls195 What's a Dremel?
    15 Mar 2011
    I am in the same sort of situation. I am thinking of watercooling in my rv02. I am thinking of removing the 180mm fans and chucking in a 60mm thick 360 rad with one set of fans and with my hd6970 there are millimeters to spare!! I just got to think about rad and pump e.c.t.
  14. khemist
    khemist What's a Dremel?
    6 Nov 2010
    Got my rads ordered for my RV02-EW - Magicool dual slim 180mm and a thick 120mm phobya in the top.
  15. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Would like to see some pics when you have this all hooked up :thumb:
  16. khemist
    6 Nov 2010
    I did do a cpu only loop in the FT02 before but it was a single 120mm up top, now i'll will be doing the gpu as well but im waiting to see what the new nvidia cards are like plus deciding on the pump, res, tubing and fittings so might be a while yet!.
  17. khemist
    6 Nov 2010
    Sent the 120 rad back for a refund in the end.
  18. lilgoth89
    12 Mar 2011
    that looks incredable m8, what temps you pulling ?
  19. Parge
    16 Jul 2010
    OMFG yellowtastic! Is that one of Mayhems pastel fluids?
  20. dirky90
    dirky90 Minimodder
    19 Mar 2012
    nice fluid!!
