I'm wanting a triple monitor set-up as i'm getting the new gtx 680 that supports three monitors. I'm having a hard time finding a monitor with a thin bezel, the closest i've found is 1.5cm - http://www.cclonline.com/product/71...-inch-Widescreen-Full-HD-LED-Monitor/MON0618/ Does anyone recommend a monitor to use for this set-up? Preferably around the £100 mark. Much appreciated.
Our resident Eyefinity man thinks that the G226 should do the job well within your budget, but admits that he hasn't tried it with those. The bezel is a little bigger than the S220 at 1.9cm, but he points out that the corners are less rounded so should look better in this setup. http://www.cclonline.com/product/85...HQLBbd-21-5-inch-Full-HD-LED-Monitor/MON0937/
