TDP problem
Discussion in 'Watercooling' started by Taigart, 30 May 2016.
  1. Taigart
    Taigart What's a Dremel?
    18 Sep 2015
    Hi guys,
    I want to cool an i5 6600k @4.5Ghz and an itx gtx970 OC
    If my calculations are correct:
    i5 @4.5Ghz = ~150W at full
    itx gtx970 OC = ~220W at full
    full load = ~370W
    According to hardware labs http://www.hardwarelabs.com/nemesis...ew=article&id=12&Itemid=118#performance-chart
    the M160GTX can dissipate 400W
    the M182GTX can dissipate 440W
    a M160 or M182 will be enough to cool my system (CPU + GPU) ?
    Thank you!
  2. Big Elf
    23 Apr 2009
    No, unless you can find some decent 80mm or 92mm fans with high static pressure which are likely to sound like jet engines if you do.
    I note that Hardware Labs don't quote the water temps with the dissipated watts so if they're 30ºC above ambient with the full 400/440W for example you'd be better with air cooling.
    I'd be looking at a dual 120mm rad as a minimum with decent fans.
  3. Taigart
    18 Sep 2015
    Thank you very much for your answer Big Elf.
    I saw these noctua fans http://noctua.at/en/nf-r8/specification
    53 m³/h 1800 RPM 17 dB
    Normally they should move enough air while sound quiet...
    The problem is that I have only 2x92mm and 2x80mm fan holes in my itx case.
    I have enough space to put a radiator for the 2x92mm while for the 2x80mm this option is available only if I install the fans outside the case (not best option for me).
    I will probably go for the M182GTX for the CPU, keeping my GPU aircooled and see if I can keep my temps around 70° @4.4/4.5Ghz....If temps will be around 50° (almost impossible) then I will add a waterblock for the gpu and see what happen :)
  4. Big Elf
    23 Apr 2009
    Those fans are unlikely to be strong enough although they might just work for a stock or lightly loaded CPU.
    Never trust a manufacturers performance figures, you don't know what their test parameters are.
