Other Software to test hardware
Discussion in 'Software' started by Uncle Psychosis, 28 Aug 2012.
  1. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    Hi folks
    I just acquired a secondhand motherboard / processor / RAM and I want to test them to make sure everything is nice and solid under load (I've had to replace some heatsinks and so on).
    What I want to do is test everything before I install windows / linux again. I'm going to boot off cd and run memtest---is there any other (free) software of a similar nature that I should set loose on it to be doubly sure?
    Cheers
    Sam
  2. saspro
    saspro IT monkey
    23 Apr 2009
    occt would stress test the cpu to check your cooling
  3. evti
    evti What's a Dremel?
    8 Aug 2012
  4. Chris666
    Chris666 What's a Dremel?
    7 Sep 2012
    intel burn test is my personal choice can be used on AMD systems as well and will push system very very hard. Tell it to use all system ram , 10 runs , if it passes you should be stable.. Watch cpu temps though..
  5. Deders
    Deders Modder
    14 Nov 2010
    I'd agree the only surefire way to know is programs like Intel burn test (which I used to test an AMD system not long ago)
    I've had Windows Memory Diagnostics report errors with my old ram that Memtest missed. It doesn't take long to install 7 and IBT will be useful as it doesn't take too long to run, If you want to do further testing then Prime64 Blend for 24 hours, but I doubt you'll need to if it's not overclocked.
    Bear in mind these only really test the CPU and Ram, along with the relative parts of the motherboard. If you feel you want to test things like the PCIe slots etc then you'll need appropriate programs or games to test it with.
  6. Stanleys
    Stanleys What's a Dremel?
    17 Sep 2012
    I am aware that there are programs to check your hardware temperatures but I do not know which one is the best to use, and while they do give me temp results I do not know if the numbers are good or not!!
  7. Deders
    Deders Modder
    14 Nov 2010
