Motherboards No PCI slot on recommended motherboards
Discussion in 'Hardware' started by chachee01, 20 May 2013.
  1. chachee01
    chachee01 What's a Dremel?
    9 May 2009
    Hi all,
    I am building a new PC and always follow the recommended builds in CPC. I notice that for the 'mid-price gaming pc' build, the suggested sound card is a Asus Xonar DG (which I already own, its fantastic) and the motherboard is the MSI Z77A-G45.
    However this mobo doesnt have a PCI slow so how is it compatible with that sound card? Any advice on a '2nd best' mobo to get with a PCI slot?
    Mobo: http://www.scan.co.uk/products/msi-z77a-g45-intel-z77-s-1155-ddr3-sata-iii-6gb-s-sata-raid-pcie-30-%28x16%29-d-sub-dvi-d-hdmi-atx
    Sound card: http://www.scan.co.uk/products/asus-xonar-dg-51-pci-sound-card-and-headphone-ampifier-oem
    High end mobo: http://www.scan.co.uk/products/asus-maximus-v-gene-intel-z77-s-1155-ddr3-sata-iii-6gb-s-pcie-30-%28x16%29-displayport-hdmi-micro-atx
    Cheers folks, love these forums.
  2. RedFlames
    23 Apr 2009
  3. chachee01
    9 May 2009
    Thanks for the reply. The reason this is a problem is because, like I said, I already own the card and I'm trying to avoid buying new gear to keep the cost down.
  4. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I'm surprised it has taken this long for the pci slot to be abandoned tbh.
    Fear not! There a thingamies like this http://www.amazon.co.uk/PCI-Express-Adapter-Card/dp/B0024CV3SA
    I'm sure there are cheaper variants, but that was the first I found. And I'm a lazy bugger with better things to do than deprive you of the experience of using Google. :p
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Yes PCI is on it's way out following floppy and pata. I would agree, upgrade to pci-e version of sound card and sell the pci one on to reduce the financial hit. Otherwise looks like there are some Z77 boards from gigabyte like the D3H that have a pci though I have no idea how 'good' those choices are.
