News Windows zero-day flaw bypasses UAC
Discussion in 'Article Discussion' started by CardJoe, 26 Nov 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    So all vista users have been bugged by UAC for absolutely no reason? I loled
  3. Shichibukai
    Shichibukai Resident Nitpicker
    29 Sep 2009
    Bahahaha...since i first saw UAC i knew it was useless, if they just discovered it only God knows how long coders have been using it >.>
  4. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    it was only time i guess, looks like MS needs to get a patch out quick smart.
  5. tom_hargreaves
    tom_hargreaves Comfy shoe wearer
    11 Mar 2010
    The first thing I do with a new install of VIsta/W7 is turn that UAC crap completely off.
    It's quite possibly more annoying than the viruses and adware.
  6. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I turned UAC off the same day I first installed Windows 7. I'd be pretty surprised if most people didn't.
  7. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I have yet to be bothered by UAC on Windows 7 apart from the installation. It s much better than it was in Vista. I don't see why people turn it off in 7.
    And I am sure Microsoft will patch it soon. People have been using UAC for no reason? Nope, it works, and this is the first one to bypass it in how many years?
  8. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    This is very serious indeed. It could bring total control to attacker and lock all other users from using anything.
    Only remedy is to shutdown the PC now and never start it again or unplug Ethernet/wifi until patch is made available now...
    All joking aside, this could produce mall-ware that even surpasses the incredibly hard to remove "fake anti virus" mall-ware.
  9. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Well so long as your Anti-Virus recognises the trojan and blocks it you should be safe.
    Might be worth checking which AV softwares recognises it and which don't.
  10. tristanperry
    tristanperry Minimodder
    22 May 2010
    LOL at Jamie's post!
    I agree though - UAC is annoying as heck and I also turn it straight off once (re)installing Windows.
    I'd imagine it'll be fixed by Microsoft fairly quickly, anywhoo.
  11. bogie170
    11 Aug 2008
    Sry double post accident.
  12. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Same here.
  13. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Well they can't leave people sitting around until 14th December to sort this one out. Doesn't mean they won't, MS tends to take its own merry time over things. Always used to turn UAC off but because of reinstalling so often recently, left it on - if it's pointless at the moment, may get back to leaving it off.
  14. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    windows 7 uac is the most anoying piece of cr@p i have ever had the misfortune to have installed on my pc
    viruses included
    a decent firewall that asks your permision to allow programs to accses certain programs and files will definatly block this easily
    becaue in order to use this it will have to run and when that happen programs like comodo will be all over it
    i pitty any fool who thinks uac and an antivirus is enough (most antivirus programs are signiture bassed so they are useless agasint the worst ones)
  15. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    What, you mean there's a way to get around UAC?
    Please, infect me with this virus!
  16. Pete J
    Pete J Employed scum
    28 Sep 2009
    Standard practice I think!
  17. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    I'm not really sure what people have against UAC. I keep it on its default setting and it hardly ever bothers me. Sure, it won't stop this particular exploit, but I'm sure it offers some degree of protection (if you don't blindly accept everything)
  18. Phil Rhodes
    27 Jul 2006
    It breaks a lot of scripts, or at least makes it impossible to run them without just OKing a huge number of requesters, thus defeating the object of scripting. You can make the argument that "scripts shouldn't need admin rights" but unfortunately back in the real world, outside a computer science exam, the reality is that they often do. UAC in this scenario seems like Windows adopting absolutely the worst characteristics of Linux, which insists on behaving like everyone's desktop computer is a VAX mainframe from the early 80s and is an absolute disaster.
    And on Windows you can't even fix it by typing "sudo bash" when you open a new command window.
  19. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    i'm glad i'm a linux user, where it protects you better than UAC would without actually running anything. remember everyone - windows' popularity is a FACTOR why it gets so much malware, but it isn't the only reason. UAC does what unix based OSes do but its more intrusive (in a bad way) and its an actual program, and a good OS will run as few processes as possible to do whatever the user wants. uac has proved to make windows extremely safe to use, but relatively its still just not good enough, even before this incident.
  20. eddtox
    7 Jan 2006
    Is PowerShell affected by that?
Tags: Add Tags
