Notebooks Need RAM help
Discussion in 'Hardware' started by low money modder!, 25 Feb 2012.
  1. low money modder!
    low money modder! Why can I not set up a web server?
    3 Jan 2012
    Hello all,
    I want to upgrade the RAM on my laptop. It is an Acer Aspire 5315, It currently has 1GB of DDR2 533Mhz. What I want to know is do I have to put in the exact same speed of memory??
    Thanks
  2. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Yes you do it's the max RAM speed the mobo can handle
  3. murraynt
    murraynt Modder
    6 Jun 2009
    Willl faster ram down clock automatically?
  4. flame696
    15 May 2009
    It might do but then does that not defeat the purpose of buying higher speed RAM?
  5. low money modder!
    3 Jan 2012
    thanks for the quick replies guys! appreciate it. :rock:
  6. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    No you don't - you can use faster memory. You won't benefit from the extra speed (the motherboard will run it at a lower frequency instead) but it may cost less (older, slower types of memory do become more expensive as their supply dries up).
    Do make sure that you get DDR2 memory though (laptops almost always use smaller SO-DIMM modules as well) - DDR, DDR2 and DDR3 are not interchangeable.
  7. jizwizard
    jizwizard Modder
    24 Dec 2010
    on that laptop you can use only 3gb and it will only work with 1gb and 2gb in the right slots. It will not take 4gb as it will blue screen on your ass. Loved my 5315 had a 2.4gz dual core in mine with a ssd and it was great for office work
