Steam Noob Steering Wheel Questions
Discussion in 'Gaming' started by HeaverNothing, 8 Nov 2014.
  1. HeaverNothing
    HeaverNothing Professional Idiot
    7 Aug 2013
    Hey Guys , I recntly bought a Logitech Driving Force GT to get into sim racing games. I've played Grid 1 & 2, Asseto Corsa , Rfactor and LFS. I'm having the same problem in all of these games where When I'm driving I get this kind of notch when changing direction where for example i'm going from about 40 degrees left to 40 degrees right and when I'm in the middle the FFB/ resistance stops is there any way to stop this as it is really off putting
    Cheers ,
    Ciaran :thumb:
  2. moose67
    moose67 Minimodder
    22 Nov 2009
    Sounds like the wheel itself if it happens on all those games. I've noticed with my wheel that it never keeps the same characteristics from game to game. I am using g27 though.
    Is there a Logitech Profiler for the GT wheel? If so there should be a test mode that will check all the motors.
  3. HeaverNothing
    7 Aug 2013
    Yes it has the test mode , but it still doesn't seem like anything is wrong
  4. Jester_612
    Jester_612 "Jammy..."
    14 Nov 2011
    In mechanical engineering there is something called backlash. It is the slack that occurs after reversing movement through a series of parts that have small gaps between them. Also in the world of Voodoo that is electricity, you'll get a loss of torque when the rotor of the motor goes through certain positions. This is felt when holding a little brushed dc motor, as it being notchy.
  5. HeaverNothing
    7 Aug 2013
    Praise the all knowing engineer :rock:
  6. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    PC Racing wheel porn! Fanatec makes some of the best racing wheels. While I was in PC Gaming support I had a look into such dark arts of gaming.
    I know its a bit off topic but, oh what a lovely wheel :)
  7. Snubbs
    Snubbs CustomPC Migration victim....
    27 Mar 2009
    The way you're describing it as "FFB/ resistance stops" suggests to me that there's a deadzone, rather than a mechanical issue.
    Check the in-game settings for a steering dead-zone. Most games have 5%~ enabled by default, which will give the sensation you're describing.
    I don't run a dead-zone, as that way you can make minor corrections. Used to have a GT wheel myself, and upgraded to a G27 a few years ago (which I've since modified for better F1 use :D).
    Hope this helps,
    James
