Just a quick bit of advise for a friend.... He has recently purchased an SR2 setup and plans to watercool it, has experience with w/c so no problems there. After looking around most people seem to use a quad rad to cool both cpus, the loop running from one CPU to the next.. His question is that; as he already has two spare 360 rads would it be possible to work something with this. Be it 360 > cpu > 360 > cpu, or 360 > 360 > cpu > cpu, He has a dual pump top over two pumps so the pump is pretty powerful... Or would he just be better off ditching it all for one quad rad? Just looking to see what you think Cheers y0
id say he would be fine with the dual 360's in either configuration. i would think rad/block/rad/clock would give more even temps but again, either should work. i think most people go for a quad for simplicity sake.
