Overclocking MSI Afterburner Problems
Discussion in 'Tech Support' started by herman_blume, 20 Aug 2012.
  1. herman_blume
    herman_blume What's a Dremel?
    25 Mar 2011
    After installing a GTX 680 MSI Afterburner no longer displays information correctly. It did initially work, but now all i see is this:
    Does anyone know why all the voltages, cock speeds etc are showing as zero? Any pointers would be much appreciated.
    :thumb:
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    I think the "+0" just means it's at the stock clock speeds and isn't overclocked. If you overclocked it before, did you click the check box to apply the overclock at system startup ?
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    This. Because of how the 6xx series works you don't set absolute speeds, you just add on speed to the base clock and then it boosts from there.
