Graphics GTX 760 or 7950?
Discussion in 'Hardware' started by total zombie, 10 Jul 2013.
  1. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    i need a new GPU but im not convinced either way? im leaning towards 7950 as i really like game mods, hd texture packs etc.. what are the community opinions ?
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    if you have room in your case for a bigger card and are not concerned with a bit extra heat and power draw then go with the 7950, it's a bit quicker at stock and overclocks like nuts
    total zombie likes this.
  3. total zombie
    2 Nov 2009
    thanks! ive looked around a bit on the 7950 and it does seem to OC really well.
  4. mikeyandrewb
    mikeyandrewb What's a Dremel?
    31 Oct 2011
    You should also get free games with the 7950, which may offset some of the slightly higher cost. Although it's best checking first, because they can run out of vouchers.
  5. total zombie
    2 Nov 2009
    thanks for the replys! ive been leaning towards the 7950 twin frozr boost edition then il OC it.
  6. teppic
    teppic What's a Dremel?
    18 Jul 2011
    Check out ocuk's one, as that comes with 8 games.
  7. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
  8. Elton
    23 Jan 2009
    Which incidentally is cheaper than a 760 and slightly faster.
  9. teppic
    18 Jul 2011
    The 670 is quite a bit more expensive than the 760...
    The 7950 outperforms them both though.
  10. Elton
    23 Jan 2009
    7950 OC'ed does.
    Get that. It's awkward how expensive the 670 is in the market.
  11. teppic
    18 Jul 2011
    Yeah, at ref clocks the 7950 and 670 are very similar, just the 7950 has loads of OC headroom.
    The 670 would be a pointless buy at the moment because of its cost.
  12. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I'd almost* be tempted to buy the Mac edition just for this sexier-than-sex cooler:
    I mean...damn.
    Yeah, if you can even find one. They're amazingly scarce, I don't know what happened. You can pretty much discount them from any prospective lineup now, unless you resort to ebay.
    *it's "almost" because you pay like £100 extra for Mac-designated versions of GPUs, because "Mac" is a synonym for "shut up and take my money".
  13. Somer_Himpson
    22 Jan 2010
    Got a GTX 670 Palit Jetstream for £205 a couple of weeks ago 2nd hand.
  14. holbob
    holbob What's a Dremel?
    3 Sep 2011
    There was an aftermarket 760 for less than 200 quid somewhere the other day. Think it was ebuyer?
  15. teppic
    18 Jul 2011
    I think your system would look far more amazing with an Asus 7970... :)
  16. Elton
    23 Jan 2009
    I'll freely quote it because that is one epicly good looking cooler.
    That said, you easily paint shrouds if that's your kind of thing.
  17. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
  18. AlienwareAndy
    7 Dec 2009
    You want to be very, VERY careful with that.
    There is a way to bork a 7950 or 7970 so that it is forced to run @ 8x PCIE.
    On the back of the card sits a resistor. If removed the card will run at 8x.
    There are certain Dell OEM cards being sold on Ebay that are borked in this way. I'm no expert on Macs but they're usually cut down PC parts so yeah, I would tread very carefully before buying anything for a Mac.
    http://forums.hardwaresecrets.com/need-help-repair/9399
    Take a read of that....
  19. Elton
    23 Jan 2009
    Meh at any rate PCI-E 3.0 x8 shouldn't be too slow. ;)
  20. AlienwareAndy
    7 Dec 2009
    Whilst it doesn't seem to hinder multiple GPU systems given the sheer might you are throwing at it it most certainly does affect a single card.
    Why on earth would you be stupid enough to spend £100 more for a card that's borked just for a white cooler?
    Surely it would make sense to buy a second hand one and either paint the cooler yourself or get it done professionally? I mean chit, you could get one custom airbrushed for £100 ffs.
    Plus 79xx stock coolers are pants any way. As soon as you clock to around a ghz they get hot and make the most god awful racket.
    It's high time that blower coolers took a running jump IMO. HATEFUL THINGS.
