Displays Smallest Bezel 1080p 23-27"
Discussion in 'Hardware' started by timmehtimmeh, 27 Jul 2014.
  1. timmehtimmeh
    timmehtimmeh Minimodder
    2 Jan 2005
    As per the title please, I have just got all excited about Elite Dangerous and might fancy swapping the last Dell 3008 on my desk for 3x slim bezel 1080p panels.
    If I were to do this, what panels might people suggest I go for? Simply put I am after cheap good panels that have super duper thin bezels. I have got 2 DVID, 1 HDMI and 1DP output on my gphx card.
    Iain
  2. Cei
    Cei pew pew pew
    22 Mar 2008
    U2414H? Pretty skinny on the edge bezels and sub-£200.
  3. heir flick
    heir flick Minimodder
    2 Feb 2007
    I would advise getting 16.10 monitors as I found 16.9 a bit too narrow for my liking
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Check the monitor in my sig. Not too expensive for IPS and a very good all rounder.
  5. faugusztin
    11 Aug 2008
    Define bezel. There are displays which have 1mm bezel, but the screen starts 6-10mm further inside :)
  6. timmehtimmeh
    2 Jan 2005
    Well in an ideal world the distance from the edge of the panel (physical) to the first and last column of pixels would be ...
    0mm
  7. GoodBytes
    20 Jan 2007
    So then U2414H is the thinnest consumer grade monitor you can get.
    Else then that, you need to get the displays found on video walls, which you can't. You need to contact the manufacture, such as LG, to order it, and they''ll come and install it, as they are fragile and knocks on the side with shader the glass. Transportation of such display is also an issue. You need to call for a quote on pricing (display(s) + installation).
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  9. timmehtimmeh
    2 Jan 2005
    Woha fancy :)
