Other Word 2007 Content Page and Roman Numerals.
Discussion in 'Software' started by Big_Adam, 29 Apr 2010.
  1. Big_Adam
    Big_Adam What's a Dremel?
    6 Jan 2004
    Hey Folks,
    Had a problem (see quote below) which is now solved but got a new one. I the content page to show Roman numerals but it just shows 1 2 3 instead rather than numerals.
    Any idea how to fix it so the content page shows numerals?
  2. wormy
    wormy Minimodder
    16 Oct 2009
    If Word 2007 is the same as 2003 (the version I'm using)...
    You just need to re-start the page numbering at each of those points. Go 'Insert' - 'Page Numbers' - 'Format' and you should find what you need. Number format drop down gives you the numbering styles, page numbering toggle allows you to re-set the number sequence.
    If it's not the same I'm afraid I can't help.
    What's the dissertation on?
  3. Big_Adam
    6 Jan 2004
    Yo, sadly its not the same thanks to the silly ribbon system ... thing.
    BUT!
    http://www.youtube.com/watch?v=NGzz2ZmLrFw
    MUWAHAHAHAHA! Anyway, dissertaion is on Cinema Box Office systems.
    And I wish to the highest heavens I never picked it, ho hum, what you going to do. Ta thought Wormy. You helped to make me google it in the right direction.
  4. wormy
    wormy Minimodder
    16 Oct 2009
    Ach, I can't watch youtube at work :( but glad you found what you needed.
    Cinema Box Office? Sounds interesting. I'm moving house soon to a place with a little local cinema, seats about 60, with a good old fashioned ticket machine under the counter that gives you those little coloured stubs from a big reel :)
    Good luck with the diss
  5. Big_Adam
    6 Jan 2004
    Cheers Wormy, but I am again stuck.
    Can't figure out why my content page won't show Roman numerals rather than just regular numbers.
    Think I shall change the title see if I can get a hand with that next.
    EDIT
    Edited original post to reflect new problem.
  6. wormy
    wormy Minimodder
    16 Oct 2009
    I'm afraid I have no idea on that one - that's when I ask the secretary for help lol Good luck!
  7. Seeks
    Seeks Minimodder
    13 Feb 2010
    The way I think you can do this is right click on the contents page "box" (for a better word) and there should be format settings. This allows you to change numbering and check default standard formats (same for referencing)
  8. Big_Adam
    6 Jan 2004
    I'm not seeing format anywhere,
  9. Seeks
    Seeks Minimodder
    13 Feb 2010
    hmmm I seem to have been mistaken what i meant was the built in styles but that failed. You need to do it like Wormy said but you probably need to press the Update contents section which should update the page numbers to the roman numerals
