Gaming Windows 7 Games Compatibility Testing
Discussion in 'Article Discussion' started by Guest-16, 22 Oct 2009.
  1. Guest-16
    Guest-16 Guest
  2. Hackjedi
    Hackjedi What's a Dremel?
    7 May 2004
    no Blizzard games tested, will they all work?
  3. BlackBabyJesus
    BlackBabyJesus What's a Dremel?
    14 Sep 2009
    I've been playing No One Lives Forever on Win 7 64-bit. No problems.
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I may try and install diablo 2 on my 64bit windows 7 install at home soon.
  5. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Just waiting in for my copy to arrive so i can do some testing.
  6. DaMightyMouse
    DaMightyMouse What's a Dremel?
    1 Aug 2008
    Couldn't get my driver for the wireless card working on the x64 RTM version, until I installed it using Vista SP2 compatibility mode. So there are scenarios where compatibility mode is actually useful.
  7. DaMightyMouse
    1 Aug 2008
    Oops I meant SP1 ...
  8. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Which version? GOTY? Ours wouldn't even install...
  9. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Retail version of Titan Quest on Vista had problems (missing driver in DX10 that was in DX9), however Steam version works fine on 7 (RC 64 version, waiting on Postie for 7Home).
    Steam version of Indy & the fate of Atlantis works great (original CD version also runs but crashes to desktop after a few minutes).
    Civ 4 on Steam works great as does UT3, Crayon Physics & World of Goo.
  10. CardJoe
    3 Apr 2007
    Nobody had any lying around. Thought about downloading a WOW trial to test, but MMOs update so fast that it didn't seem worthwhile tbh...
  11. antec_ati
    antec_ati What's a Dremel?
    2 Dec 2008
    D II works fine on windows 7 beta so should be no prob peace Antec_Ati
  12. antec_ati
    2 Dec 2008
    you'll have to install it in the x86 and probably under xp2
  13. The boy 4rm oz
    10 Apr 2008
    I just have a question, I skimmed the article and you may have already stated this. Did you use Windows 7 Ultimate? Ultimate is the only version which actually has the XP compatibility mode so if you were using a different version this may fix some issues.
    I can't wait to get my FREE!!! copy from Micro$oft :D.
  14. Venares
    Venares What's a Dremel?
    22 Jun 2008
    Been happily playing WC3 and WoW on the RC for the last 6 months :D
  15. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Beyond Good and Evil (Steam Version) Works fine on 7 x64, albeit with some graphical glitches that aren't bad enough for me to warrant investigating :)
  16. CardJoe
    3 Apr 2007
    Read the article. It answers that question.
    I'm only not answering it here because it's not as simple as your question makes out. We did use Ultimate, but there are two types of XP mode. There's an XP Mode intended for businesses wanting increased compatibility in office software and then there's the general purpose XP Compatibility mode which is in all versions of Windows and has been since XP. The 'True XP Mode' intended for businesses is actually completely unsuitable for games because of the way it isolates the graphics drivers. The article discusses this in more depth
  17. The boy 4rm oz
    10 Apr 2008
    I would read but I have an assignment to finish, looks like I will have to do it later.
    *EDIT*
    Cheers, thanks for that Joe.
  18. rhuitron
    rhuitron Bump? What Bump?
    15 Aug 2006
    How about Tribes2?
  19. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    RA2, RA3 works.
  20. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You didn't test any Worms? :eek:
Tags: Add Tags
