Motherboards 3 or 4 way sli/crossfire
Discussion in 'Hardware' started by darren1678, 5 Jul 2011.
  1. darren1678
    darren1678 What's a Dremel?
    20 Jan 2007
    hay everyone looking for a cheap 3 or 4 way sli/crossfire motherboard any sugestions
    i dont mind if it's am2, am2+, am3
    but it's gotta handle 3 or 4 graphics cards without getting out the soldering iron to modify a 1x pci-e connector.:blah::blah::blah:
    any suggestions
  2. Deders
    Deders Modder
    14 Nov 2010
    What would you be using it for?
  3. darren1678
    20 Jan 2007
    bitcoin mining
  4. KidMod-Southpaw
    28 Sep 2010
    Generally, they advertise even mid range boards as being 4 way SLI and crossfire X compatible, the difference is, it can only be 2 GTX 590's or 2 6990's. I can only suggest these: http://www.scan.co.uk/products/giga...-20-ddr3-1866(oc)-sata-6gb-s-sata-raid-xl-atx
    http://www.scan.co.uk/products/asus...e-20-(x16)-ddr3-2133-2000-sata-6gb-s-raid-atx
    http://www.scan.co.uk/products/asus...0(x16)-ddr3-2133(oc)-sata-6gb-s-sata-raid-atx
    Looking at it, you do not need a multi GPU config to do this. You can pop them in without a bridge. The most affordable you can get is the crosshair IV, which has plummeted in price: http://www.scan.co.uk/products/asus...-e-20-ddr3-1600-1800-1866-sata-6gb-s-raid-atx
  5. darren1678
    20 Jan 2007
    those boards look awesome but are too expensive, really looking too spend less than £100 ex shipping, on a three or four port pcie x16 slot motherboard, or motherboard with open ended x1 or x4 pcie slots as thru put to the cards isnt important for my setup
    your right i only really used crossfire descritivly, dont really intend to implement it
  6. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    Ah a fellow miner. I would be wary with the recent fall in prices. BTC are trading down, and if you see TH or MTGOX go below $10 then watch out for a freefall in price.
  7. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    I really don't remember ever seeing a good mobo at or below your budget with more than 2 slots... and even boards with moer than 2 slots aren't usually all 16x unless it's a higher end chipset.
  8. KidMod-Southpaw
    28 Sep 2010
  9. darren1678
    20 Jan 2007
    your right they usually are pcie 16x but with pcie 8x electricals, i'm not worried about thru put just that they will fit a pcie gpu.
    from what i gather pcie 1x slots would be fine aslong as they have open ends:D
  10. darren1678
    20 Jan 2007
  11. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    There area few of the new 990 chipset am3+ boards from MSI and Gigabyte that have 4 x16@x8 slots. Probably still more than you're looking to spend though.
  12. saspro
    saspro IT monkey
    23 Apr 2009
    MSI K9A2 Platinum support 4 cards (& in crossfire if you wanted).
    I've got one going spare if you're interested.
  13. Randomeclipse
    Randomeclipse Minimodder
    11 Jan 2011
    What's bitcoin mining?
  14. darren1678
    20 Jan 2007
    google it, it's kinda like seti at home/ folding at home but you can make money!!:jawdrop:
  15. Randomeclipse
    11 Jan 2011
    Hmm, interesting.
    What sort of money are we talking, enough to pay the electricity bill of leaving your PC on or being able to buy a piece of pc hardware each month say?
  16. darren1678
    20 Jan 2007
    enought to pay back your invest meant in 2 or 3 months
    e.g. all electrical plus the cost of your rigg
    your gpu's have to be ati 4/5/6 the more shaders the better
    nvidia just doesnt cut the mustard top end nividia is 3 or 4 times slower than a 5770
    the sweet spot just now gotta be the 5850 for price/performance
    a 5770 running 24x7 will net you approx $20 per week
    if your gonna do it sign upto slushes pool
  17. Randomeclipse
    11 Jan 2011
    Interesting stuff indeed, thanks for the info darren.
  18. darren1678
    20 Jan 2007
    np
  19. krishan
    krishan Minimodder
    26 May 2011
  20. KidMod-Southpaw
    28 Sep 2010
