Scratch Build – In Progress Stainless Tower By JD Design
Discussion in 'Project Logs' started by JD Design, 19 Feb 2014.
  1. JD Design
    JD Design What's a Dremel?
    13 Feb 2014
    Hello everyone! I introduce myself, my name is jerem alias JD Design.
    I'm 26, I live in France near Geneva so sorry for my very bad english. I work in the metal, I'm a welder.
    I made the WaterWall
    All pics:
    https://www.facebook.com/media/set/?set=a.707763922584818.1073741833.634371046590773&type=3
    https://www.facebook.com/media/set/?set=a.729725597055317.1073741834.634371046590773&type=3
    I also made the Black Pearl
    All pics:
    https://www.facebook.com/media/set/?set=a.656651554362722.1073741832.634371046590773&type=3
    https://www.facebook.com/media/set/?set=a.634384906589387.1073741829.634371046590773&type=3
    Today, I am pleased to present my new project.
    The main feature of this project is its tube structure which has the dual function: support and ranks cables.
    Thus all cables and tubing of watercooling pass inside the structure.
    This project is the most clean possible.
    The second feature of this case is its cooling system fully realize stainless steel (tank 290 mm X 82 mm diameter)
    All 100% Home Made ...
    Sponsor:
    Aquatuning France => http://www.aquatuning.fr/
    Asus France Republic of gamers => http://www.republic-of-gamers.fr/
  2. JD Design
    13 Feb 2014
    My project began in January, so here is a summary of work to date.
    Part 1/2:
    To be continued ...
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Very nice craftmanship.
    Your waterfall case was very nice as well.
  4. Cheapskate
    13 May 2007
    Very tasty.:D
  5. JD Design
    13 Feb 2014
    thank you for your interest.
    part 2/2
    partie 2
    That is the state of affairs it stands right now.
    To be continued...
  6. JD Design
    13 Feb 2014
    Hi, thank you for your interest
    Following the summary,part 2/2
    To be continued...
  7. JD Design
    13 Feb 2014
    hi,
    I have a little problem with my posts, I posted 2 times more but it does not work. : Duh:
    Here are the part 2/2
    To be continued...
  8. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Metalworking to be jealous of for sure. :jawdrop:
  9. JD Design
    13 Feb 2014
    hi,
    Thank you for your interest ;)
    To be continued... :thumb:
  10. Razarach
    Razarach Minimodder
    28 Jan 2009
    Wow, this is awesome. ;)
  11. The_Crapman
    5 Dec 2011
    Really stunning work.
  12. Cheapskate
    13 May 2007
    Oh, You totally have to make the reservoir look like it's floating somehow. That would be cool.:D
    Perhaps mount it with two thin sheets or mount the res lines near the middle. -The intake would need a siphon to the bottom like that, a little tricky to get the pump primed if you did that...
    -Sorry, I ramble.:(
  13. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    Did you realize this glass by yourself ? :hehe:
    this is realy good work here, keep modding !!
  14. JD Design
    13 Feb 2014
    Hi, Thanks for the compliments!
    Today, I have started the manufacture of Radbox.
    Small teaser:
    To be continued:thumb:
  15. imersa
    imersa Parvum Princess
    9 Apr 2009
    Amazing metal work. Subbed.
  16. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Looks awesome will keep a eye on this!
  17. JD Design
    13 Feb 2014
    To be continued :dremel:
  18. imersa
    9 Apr 2009
    It's just insane. You cut and form things to a level probably better than my CNC! My hat of to you sir :)
  19. lowfat
    lowfat Minimodder
    4 Jul 2013
    You used a file and drill for that? You just blew my mind. :jawdrop:
  20. Cheapskate
    13 May 2007
    Wait... Is the text just photoshop at this point? -Or did you mill or etch and fill with black paint?
    Hand cutting thick stainless steel.:thumb: I tried that once. It was a LOT of work.
