Scratch Build – In Progress CERBERO AK
Discussion in 'Project Logs' started by warboy, 11 Aug 2016.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    Hello everyone!
    finally a bit of time to post a little something
    Work on CERBERO WARBOY continue ...
    I opened a new thread because it completely changes the hardware configuration and finally ride on the rigid tubes !.
    Start thanking
    AK INFORMATICA
    COOLER MASTER
    BITFENIX
    For the uninitiated CERBERO is a PC chassis made from square sections 4x4 cm for 2mm thick all cut and welded with the art of a Master Blacksmith and painted and airbrushed from me.
    NEW hardware configuration will be:
    MOTHERBOARD: MSI Z170A GAMING carbon gaming pro
    CPU: Intel I7 6700k
    RAM: HyperX Predator HX421C13PBK4/32 4x8GB DDR4
    VIDEO CARD: MSI GTX970 4G
    SSD: HyperX SAVAGE SSD 240 GB
    SSD M.2: HyperX Predator SSD da 240 GB
    HD: WD Hard Disk 1 TB SATA 3.5
    PSU: Cooler Master V1000
    KIT : Bitfenix Alchemy2.0 Modular Cable for CM V1000
    FAN: 6 JetFlo White
    The liquid cooling system includes:
    CONTROLLER: Lamptron CW611 Water Cooling Controller
    SSD WB: EK-FC970 GTX TFX
    VIDEO CARD BP: EK-FC970 GTX TFX Backplate
    WB: Watercool HEATKILLER® IV PRO ACRYL
    RADIATOR: Alphacool NexXxoS ST30 Full Copper radiatore 360mm
    POMP: EK-XRES 100 DDC 3.2 PWM Elite (incl. pump)
    ADDITIVE: Mayhems Additivo X1 UV GREEN
    TUBI: EK-HD Tube 10/12mm
    FITTING: EK-HDC
  2. warboy
    24 Nov 2011
    Small step back to present some stage of processing CERBERO:
  3. warboy
    24 Nov 2011
    some shots to power supply Cooler Master V1000 which combine the cables BitFenixed Alchemy2.0 Modular Cable for CM V1000
  4. warboy
    24 Nov 2011
    Let's move on to the processor and motherboard
    msi Z170A GAMING PRO CARBON
    RAM HyperX Predator HX421C13PBK4/32 4x8GB DDR4
  5. warboy
    24 Nov 2011
    msi GTX 970 GAMING 4G
    SSD HyperX SAVAGE SSD 240 GB
  6. warboy
    24 Nov 2011
    Now I show you some photos of the liquid cooling components:
  7. warboy
    24 Nov 2011
    Finally we start with the assembly
  8. warboy
    24 Nov 2011
  9. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Did you get a mini screwdriver with your SSD? Is that a bundle, or part of a sponsorship thing?
  10. warboy
    24 Nov 2011
    that is a part of SSD bundel ;):clap::clap:
  11. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    :rock: Seguo anche qui.
    :rock: I follow here.
  12. twister7800gtx
    twister7800gtx Minimodder
    2 Nov 2011
  13. warboy
    24 Nov 2011
    Thanks Guys! ;)
  14. warboy
    24 Nov 2011
    continuing with the assembly
  15. warboy
    24 Nov 2011
    and start with rigid tubes
  16. warboy
    24 Nov 2011
    and soon more pics :)
  17. Cheapskate
    13 May 2007
    Hard tubing makes it look even better. :thumb: That hanging hose from before was distracting. -Like it was on life support. :D
  18. GeneralFun
    GeneralFun Lurker with tools
    24 Feb 2014
  19. warboy
    24 Nov 2011
    Thanks!!
  20. warboy
    24 Nov 2011
    and here CERBERO AK at MILAN GAMES WEEK 2016
    warboy e AkBoss
