Modding Xbox 360
Discussion in 'Modding' started by kev8alot, 18 Jun 2011.
  1. kev8alot
    kev8alot What's a Dremel?
    18 Jun 2011
    Hello,
    I was recently thinking about getting an xbox 360 however I have a computer I use for gaming and I like it that way. Here's the thing, can you disassemble an xbox 360 and install the drive into a computer just like a 5.25 drive and use a sata and power connector with existing computer hardware? Mainly I want my xbox 360 to work with my computer hardware.
    Spec!! XD
    Intel DX58SO Gaming Motherboard
    Intel Core i7 960 3.2 Ghz
    Ati Radeon HD 5750
    4 Gb of DDR3 gskill RAM
    Modular PSU
    Cooler Master Case
    Any Help
  2. bulldogjeff
    2 Mar 2010
    If I'm right in thinking that you want to combined the 2 then it's impossible. Or is it that you want to build the Xbox into the rig and use a standard DVD drive?
  3. chrismarkham1982
    chrismarkham1982 Multimodder
    1 Apr 2010
    impossible im affraid, you can take one apart and fit it into a pc case but you cant just use the dvd drive from the console to play xbox games on your pc, they are two diferent architectures
  4. kev8alot
    18 Jun 2011
    chris,
    that makes sense and from my understanding the xbox also using a different type of bios, different than from the computer bios. I was thinking more about modding the case to hold the 360. Do you know roughly the parts and the size of the board (if I do do it I wanna place it on the bottom of my case) and I am curious if it'll fit.
  5. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    the drive in a 360 is a 5.25" format
    but there is no 360 emulator
    so its impossible
  6. ozzylow
    ozzylow What's a Dremel?
    22 May 2011
    Just get a big enough case to hold the PC and Xbox in side. 2 Motherboards, 2 Disc Drives. Easy enough, If you need help with pin outs let me know and i can point you in the right direction.
  7. kev8alot
    18 Jun 2011
    Lol, thanks disturbed and ozzy. Disturbed I wasn't planning on using an emulator just making room in the case like ozzy said. Yeah I checked out some cases and what not, they are cool and all but I'm not looking for something the size of a small filing cabinet, lol. Anyway thanks for the posts guys. Pretty soon I'm going to paint my interior case and organize the cables. I'll upload some photos of it when I'm done. Thanks again
  8. Yaka
    Yaka Multimodder
    26 Jun 2005
