News Intel Atom C2000 chips fingered for hardware failures
Discussion in 'Article Discussion' started by Gareth Halfacree, 8 Feb 2017.
  1. Gareth Halfacree
    4 Dec 2007
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    Time to check if we have any 9Ks around then!
  3. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    If you are big and monopolistic enough you don't have to care I guess.
  4. Mister_Tad
    27 Dec 2002
    Oof. I nearly built my server around a C2750, glad I opted for the easy way out with a microserver in the end!
  5. Taua
    Taua What's a Dremel?
    20 Sep 2014
    "flaw in the chip that causes it to die entirely and irrecoverably after a period of time."
    d'oh they set the silicon fuse a bit too short!
  6. TheMadDutchDude
    23 Aug 2013
    Didn't they learn from the P67 chipset which had a voltage leak, causing it to die...? Tut tut.
