Watercooling Removing dye stains
Discussion in 'Hardware' started by jamsand, 26 Nov 2013.
  1. jamsand
    jamsand Minimodder
    21 May 2011
    Trying to remove a fairly hefty dye stain from my acrylic nickle full cover block from EK for a 5870, it's a lovely shade of redish pink. Any idea's? thinking something like vinegar although will that not cause clouding or cracking?
  2. Big Elf
    23 Apr 2009
    Soft bristled toothbrush and soap. I use a mild bleach to remove dye from acrylic but shouldn't be needed on nickel. At a push something like Brasso or Autosol will do it but can remove thin layers of plating. It's possible that what you're seeing is dyed copper where the nickel has come off.
    Not Vinegar.
    Also posted in your other thread.
  3. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I have no clue if this is true or not but I recall people using ketchup to clean up stained blocks.
  4. jinq-sea
    15 Oct 2012
    Ketchup has a high vinegar content! :)
    (and tomatoes are really acidic)
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Use some sodium hydrosulfite. It's a dye remover and should be safe for acrylic blocks and reservoirs.
