need advice- build planning
Discussion in 'Watercooling' started by 8-BiT, 1 Jun 2015.
  1. 8-BiT
    8-BiT What's a Dremel?
    23 Nov 2014
    Planning out a SFF custom build and trying to find what the limits of water cooling are with a few different setups. I still might go full air cooling but like the challenge and the option to go water cooling.
    hardware I am looking to cool will be i5 or i7 broadwell "if they ever release" and a gtx 970-980ti
    setup one-
    single- 240mm rad , 2 gentle typhoons 1850rpm <-- not sure this will fit.
    setup 2
    2x 120mm rad with a GT 1850rpm in the middle of them
    setup 3
    2x dual 80mm rads with 4 fans. not sure on what fans I would use yet.
    any thought suggestion would greatly help
    case size is 12x4x10 inches
  2. phuzz
    phuzz This is a title
    28 May 2004
    The thickness of the radiators will have a big effect on how well they cool. Generally though you're going to be close to the limit trying to cool that hardware with 240mm of radiator, but with decent rads and powerful fans it should cope.
    Do you have any pictures of the case you can show us?
  3. 8-BiT
    23 Nov 2014
    Unfortunately no.
    Kinda top secret until I start the build I might make the case 5" wide so I don't have to lay down the GPU should yield me some more room that way.
    Broadwell is out also, I picked up a i7 4770k for next to nothing so that more than likely will be the cpu now.
  4. theshadow2001
    3 May 2012
    I thought it was more to do with the fan area than the thicknesses.
  5. David
    7 Apr 2009
    Surface area, not fan area. A thicker rad means broader fins and greater cooling potential. :)
  6. theshadow2001
    3 May 2012
    Yes fine, but how thick does a radiator have to be before it has the equivalent cooling potential of a thin rad twice its size.
  7. phuzz
    28 May 2004
    Approximately twice as thick (so you could look at it as two rads stacked one in front of the other). However, a thicker rad will be more restrictive to airflow, so you'll need a more powerful fan, but if it's a longer rad then you'll need more fans so...
    Eg a slim 240mm radiator will cool about(ish) as well as a 120mm that's twice as thick.
    Of course, then things like fin density and how restrictive they are to the water start playing a part.
    Personally I've always had to chose radiators based on the available space first, and other considerations later.
  8. theshadow2001
    3 May 2012
    It gets tricky though doesn't it. Not only does the restriction increase for a rad half the width and twice thickness of another, but the air is also a bit warmer once it goes through 50% of the radiator.
    Anyway I'm derailing 8-bit's thread. Sorry :grr:
  9. 8-BiT
    23 Nov 2014
    I am sick as a dog ,got some type of summer fever. I'll get some of measurements done and get back to you guys when I feel better.
    Thanks for you help
