Build Advice Titan Fenrir & Asus Crosshair II
Discussion in 'Hardware' started by 51lver, 17 Dec 2009.
  1. 51lver
    51lver Forever Hungry
    31 Aug 2009
    Would I have any clearance issues if using 8 GB Corsair Dominator Kit?
  2. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    I doubt you will have any clearance issues so long as you have the fan facing away from the RAM as heatsinks are design to fit inbetween the components around them. However never used one of those dominator RAM cooling fans however they must fit otherwise it would be a terrrible design flaw.
