Case Mod - In Progress PEXON' / PARVUM Vanilla / ITX Parvum / New Ram and Cable Management
Discussion in 'Project Logs' started by shrop, 14 Aug 2014.
  1. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Time for another build log; this time around another Parvum case. A while back (i50?!) A couple of us threw the idea around for an inverted ITX case with some more bang. I like the idea of the ITX form factor, still plenty of performance when running 1 GPU, but the small form factor cases on the market are a little lacking in terms of W/C compatibility.
    The idea evolved from me and HackJoe talking about an FT03 style case with a slightly different layout allowing for the I/O cables to be better accounted for. The case can support 240mm in 30mm thickness and a 120mm on the top.
    The parts used for the first iteration (air cooled due to time restrictions because of i52) of this build are as follows:-
    -Custom Parvum ITX case
    -Zotac Z68 ITX mobo
    -Intel i5 2500K
    -Asus R9 280X DU CII
    -Samsung F3 1TB
    -OCZ Vertex 60GB SSD
    -Silverstone Strider Gold 750W
    -Hyper-X 8GB Savage @ 1866
    Please note, this is just temporary gear that does not do the case justice, it will be aircooled for i52 and watercooled with new mobo etc in, for i53 in winter.
    Stage 1:- Unpacking and building the case
    Stage 2:- Starting the sleeving
    Massive thank you to the continued support from 2 good friends, Justin and Shaun over at Parvum
    Big thanks to Pascal at Aquatuning for sponsoring this build with watercooling components.
  2. shrop
    22 Jul 2011
    reserved
  3. shrop
    22 Jul 2011
    The box the case came in was a little wet when it arrived, thankfully, there was no damage to the case. Upon opening the box, I was greeted by a seriously epic colour combo, vanilla coke.
    Starting to piece the case together. A lot of screwing and unscrewing to get some of the blanking panels in their rightful places...
    The bottom panel, where all the I/O cables will be routed is super freaking neat. The very bottom has a nice clear sheet of acrylic so you can reach up and route the cables to their respective places.
    The Zotac board installed on the lovely, thick and clear mobo tray.
    The SSD/ HDD rail installed
    All the panels installed, it looks EPIC
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    This project is beautiful mate.
  5. shrop
    22 Jul 2011
    Thank you very much sir.
    Justin and Shaun did an incredible job on this for me
  6. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Looking forward to this mate, looks lovely and add in your skills, voila, got a top notch build!
  7. shrop
    22 Jul 2011
    Thanks dude, much appreciated.
    More pics will be uploaded tonight. Got a good start on the cabling and LEDs last night. Its just a shame I haven't got some nice Z97 gear to put in it yet!
  8. pafalco
    pafalco What's a Dremel?
    1 Sep 2014
    Subbed
    Avidly waiting for updates,this is exactly what I am looking for, a Parvum ITX case with added watercooling possibilities
    what is the space (depth) available for the 240 rad?
    will it be possible a loop including the cpu, a 4790K and a Nvidia 670 GPU?
    Hope the Parvum team will produce a similar case for customers, as i imagine that this is a custom fabrication
  9. shrop
    22 Jul 2011
    Sorry for the delay had a little bit of an issue at LAN with the ITX Mobo.
    Updates will be coming soon.
    Not started W/Cing yet, but there is ample room up front for a 30mm thick 240 with standard fans and easy enough room up top for 30 maybe even a 45 in the top.
  10. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Damn you ZOTAC!!!!!!!!!!!
  11. shrop
    22 Jul 2011
  12. KidMod-Southpaw
    28 Sep 2010
    Love the name and choice of colours here James! Looking forward to more!
  13. shrop
    22 Jul 2011
    Will be slowly updating this... Some of these pics are from a couple of weeks ago (before LAN). Currently waiting on WC gear, planning on swapping GPU as its too big and wondering what the flip to do about getting a decent ITX mobo
    Testing up some LED strips, in red this time.
    Can you tell what I am going to do with these?
    any ideas?
    they work...
    Will be powering them directly from the PSU with an 8 PIN CPU connector.
    Installed on the mobo tray...
    Loooovely...
    Nice, subtle underglow
    Thanks for looking, cable update tomorrow! :)
  14. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Looking good buddy!
    J.
  15. Kerroin
    Kerroin What's a Dremel?
    7 Jul 2014
    Nice!
    Just need a Coke logo on the side :)
  16. shrop
    22 Jul 2011
    Right, another little update. This time and of course, my favourite part; CABLES!
    Red SATA cables in MDPC, for now. I have some some Vanilla sands in SATA size, which may look better. I will have a look soon.
    Got some sleeve (again in red) on the power switch, with plenty of spare on the switch end for room to manage the cables
    Got some LEDs wire up for the roof
    Again, powered the LEDs from the spare 8 Pin CPU connector
    Looking snazzy
    GPU is in, its a little big as it is non reference. I will look at getting something like a 280 (ref PCB) or a 760
    CPU cooler installed
    I like the Noctua fans, I plan on using them for them for the rads too
    24 pin sleeved - not the final sleeving pattern.
    Thanks for looking as always!
  17. Bad Fenny
    Bad Fenny What's a Dremel?
    20 Aug 2014
    Looking good :thumb: I remember vanilla coke - awful stuff - but the case colouring you have employed is amazing. Are you going to have some coke symbols added to the case artwork?
    Cheers
    Fen
  18. shrop
    22 Jul 2011
    I love Vanilla Coke, it was awesome, will have to get some for the final photos.
    Not going to go to the extreme of any logos, bar the Parvum one.
    Seems as though 'Vanilla Coke' has stuck now for the project name, I'm happy with that :)
  19. montymole
    montymole Rigid Tubist
    24 May 2010
    Love the colors here very nice project subbed :)
  20. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Hows this lookin now chap?
    J.
