Case Mod - In Progress Project: Torque By CK
Discussion in 'Project Logs' started by ComputerKing, 13 Jan 2009.
  1. ComputerKing
    8 Sep 2006
    Hey guys... Finally I'm starting my Project :rock:
    I will talk later, But this is what I will have to do tomorrow....
    1- Buy Case And HD
    2- Mod motherboard heat sink and change paste under them.
    3- Lap The CPU and The heat sink
    For today I was cleaning my hardware, and organizing my HD. So tomorrow I think i will have time to buy The CASE and a 1TB Hard disk.
    Latter on ( during this week ) I will post my new 22 " and 4870 1GB and maybe the sound card.
    I just wanted to keep my word that I will start today :) here you go guys pics of my TRUE!!!
  2. Jipa
    5 Feb 2004
    Ok just take it easy this time and do things carefully :D I believe in you, CK!
  3. jhanlon303
    7 Sep 2006
    Yippee it begins!!!!!!!!!!!!!!!!!!!!!
    More for me to watch. [​IMG] [​IMG]
    john
  4. ComputerKing
    8 Sep 2006
  5. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    Can't wait to see where this goes!!
    Good Luck:thumb:
  6. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Nice hardware :) Now go on with the modding :p
  7. turboshifter
    turboshifter What's a Dremel?
    29 Oct 2008
    some cable management please
    i hate to see beautiful hardware in a madd of tangles unsightly wires
  8. mansueto
    mansueto Too broke to mod
    31 Aug 2007
  9. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    those types of heatspreaders are let down by the crappy thermal bubble gum there stuck on with.
    The tiny sinks CK has used could be improved by using some thermal epoxy which would require balls as you'll never get the sinks off safely. But would offer better cooling.
  10. mansueto
    31 Aug 2007
    Some of them do use clip designs, and you could just get rid of the paste they come with and apply your own?
  11. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    All of the heatspreaders form ram I have had use that bad thermal sticker stuff. I just get it off and apply a little bit of AS5, and it works like a charm. Just make sure it stays on there tight.
  12. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Long time, no see ComputerKing! :)
    Do you have any idea of where this mod is going? Or are you just figuring out along the way? :)
  13. ComputerKing
    8 Sep 2006
    just figuring out along the way :rock:
    Thanks to all comments
  14. Cheapskate
    13 May 2007
    Nice gear. When are we going to get you interested in water cooling?
    -Join us on the dark side.:D
  15. jhanlon303
    7 Sep 2006
    I've used that plan before! Only real plans I ever do are work related and too much detail to be done for fun.
    Go with the flow. Remember if it doesn't look right we'll let you know - [​IMG]
    john
  16. ComputerKing
    8 Sep 2006
    Mobo Tray Mod :
    Before
    After
    New Hardware :D Amazing stuff ;)
  17. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    sweet lord .... ComputerKing what a mess ;P This graphic card is Very noisy i think :>
    But i'm waiting more of your work !
    Go On...
  18. ComputerKing
    8 Sep 2006
    Yeah man :) I'm working very dam slowly :) and on cheap :)
    That what happen when you are modding and run out of money ;(
  19. Burnout21
    9 Sep 2005
    why the 3870X2, isn't a single 4870 cheaper and faster?
  20. Guest-23315
    Guest-23315 Guest
    ^^ Aye... I think a 4850 is with a little OC'ing actually.
