Watercooling Antec Kuhler 620 Pipe Diameter
Discussion in 'Hardware' started by The_Crapman, 8 Apr 2012.
  1. The_Crapman
    5 Dec 2011
    Does anyone know the pipe diameter for the Antec Kuhler 620?
    I want to mod one to include the NB heatsink which is incorperated into my Striker II NSE, but not sure if the standar piping will fit either directly, or with the accessories provided with the board.
    The NB Heatsink
    The tubing accessories, with the small section of tube fitting to the heatsink, then them to the white adapters which you'd attach your standard piping to.
  2. Auxilliary
    Auxilliary Crashes into space stations
    27 Jan 2011
    Just measured the tubing on mine, diameter of it is 1.25cm ish, it is rather hard to be 100% when all you have to hand is a tape measure and a see through ruler...
  3. The_Crapman
    5 Dec 2011
    ha ha. cool thanks man. the od of the tubing that comes with the board is 12mm so it might just fit! time to order and see me thinks!
  4. Auxilliary
    27 Jan 2011
    yeh, it is definitely 1.25cm - 1.2cm at the smallest
