Post-apocalyptic future story written by Masbuskado: Year 2099, the opprezzors rule the world while a few still resist. 40+ hours of 2d/3d design on CorelDraw and Rhino3d with a few version updates, this machine seek for rebels to finally end any resistance. 3D Render: New parts:
wait... Ohhhh!!! I see what you did there Renders look pretty sweet mate! Not my style asthetically, but I'm excited to see how it comes together!
Crazy, I like looks like it might be quite a bit on the handle with care side but it's still awesome.
Thanks! Maybe... but will be extremely easy to dissasemble and carry anywhere in a small box. Starting with the Hard disk sockets and assembly the arms
Continue assembly the parts: cutting the main support, the hard disk sockets and an aluminium reinforcement for weight in the arms.
Adding some details to the skull-missiles, sleeving the led switch and drill the holes for general assembly.
While i was testing the total weight of material with hardware installed, i realized that the union parts was under torque and deforming the material, risking to break. The solution was cut the union closer each other and prevent any rupture. New assembly shows the joints better now. After that, painting the plastic skull, disassemble the motherboard sink for mod and giving new attitude with the metallic red over the project.
Here is where all the work ends... few months of sketching, modifications, reviews from friends and updates, help me to build this project to reality. Thinking in build some thing different for the common square shapes, the idea evolves thinking in a combination of an aircraft with human skeletal forms, using the hardware advantage for supports and combine them (hdd, cables, switches), as part of the general theme. First scratch for me, but not the last, haunted for explore new unconventional designs. The final picts, Red 'n Black theme with white lights, hope you like it! Cheers
