Scratch Build – In Progress " Dragon Desk" ( build in progress )
Discussion in 'Project Logs' started by Gas_designs, 3 Jul 2015.
  1. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Here we are guys , with my new project Desk .... You have the right of fixed desk.
    For almost six months I put in various dance projects , drawing the design with Solidworks , Corel , and DraftSight.
    In the end neither left a desk all aluminum , with 3 mm thick , laser-cut , and with various robotic bending ..... all this made ​​at my expense .. in a laser cutting company in my area , I'm going to withdraw tomorrow afternoon.
    Then they made a couple of changes will have various levels: holes and welding . I prefer to do a little hand , so I have to be fun for the next few months .... as a true modder should also get their hands dirty.
    Material used
    Alluminium thickness 3mm
    Steel screws
    Plexyglass
    Sponsor By*
    Mb* Hoping to get a partnership
    Cpu* Hoping to get a partnership
    Ssd* n°2 - Corsair Force LX 512GB
    HD* WD RE 4 TB Enterprise Hard Drive - WD4000FYYZ
    Psu* Corsair HX750i
    Gpu* Asus Strix - GeForce GTX 970, OC, 4 GB
    Ram* 32GB - Corsair Dominator Platinum C9 1600MHz DRAM DDR3 da 16GB (4 x 8GB)
    Keyboard* Corsair Vengeance K70 RGB Mechanical Gaming Keyboard — Cherry MX Red.
    Rheobus* n°2 - Lamptron CW611
    Fans* n°12 - Spectre-pro White
    Fans* n°2 - Corsair SP120 High Performance
    Pump* n°2 - Alphacool VPP655 - PWM
    Reservoir* n°2 - Phobya Balancer 250 black nickel
    Radiator* n°2 - Alphacool NexXxoS XT45 Full Copper 360mm
    Tube* Rigido e morbido Alphacool
    Fittings* Alphacool Fittings
    Gpu Block* Hoping to get a partnership
    Cpu Block* Hoping to get a partnership
    **VIDEO**
  2. Gas_designs
    29 Sep 2014
  3. Gas_designs
    29 Sep 2014
    Hello guys , this morning I insert the aluminum components of the desk. :thumb:
    A few photos of the work, made ​​by the owner of the company. :D
    Images: :clap:
  4. Gas_designs
    29 Sep 2014
    Here we are guys , with the first step, welding of aluminum:: :thumb:
    And now we wait for the rest of the welds :D
  5. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    Liking the look of this, anything with dragons gets my vote :clap:
  6. Gas_designs
    29 Sep 2014
    Thanks a lot .... :thumb:
  7. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    nice start mate! :) really like the design!
  8. TATH
    TATH Minimodder
    19 Jan 2015
    A desk in 60 seconds. :wallbash:
    I have been working on my desk for 5 months. :D
    "yes you need dirty hands" .
    What are the dimensions of your desk "or is it a secret :D
  9. Gas_designs
    29 Sep 2014
    Thanks to Corsair to sponsor my project Dragon Desk, and to Jon for collaboration. :thumb:
  10. Gas_designs
    29 Sep 2014
    Thanks to Aquatuning Gmbh to sponsor my project Dragon Desk, and to Peter for collaboration. :thumb:
  11. Gas_designs
    29 Sep 2014
  12. Gas_designs
    29 Sep 2014
    Special thanks goes to Lamptron​​, for the trust you gave me in the project , for providing all the material. :thumb:
  13. Gas_designs
    29 Sep 2014
    Here we go guys, I present my new purchase made this afternoon ... :thumb:
  14. Gas_designs
    29 Sep 2014
    Here we are guys... Today we start with the first cuts, after taking all measures perfect: :thumb:
    I start from the plate that will accommodate the motherboard. ::D
    I prepare my tools and start:: :D
    I start making some points on the parts to be drilled:
    So with a cup 19mm, I start to make holes:
    And here it is completely perforated:
  15. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Seems like this is a higher standard from most of the desk builds.
    I can see this becoming quite nice.
    Sub!
  16. Gas_designs
    29 Sep 2014
    Here it is over, after I helped out with the jigsaw, and files: :thumb:
    Now that we have seen me do track the slab where I'll place the IO , cutting the compartment. :)
    Putting in security , with glasses use the hose: :dremel:
    And here it is in position:
    The signs you see on the left , are still to be determined .... :idea:
  17. Gas_designs
    29 Sep 2014
    Another step :thumb:
    Today we begin to fix the part of 2 Lamptron CW611.
    So as my usual , I masquerade whole part , and I do my tracks. :D
    Now I enter 2 Lamptron into the slots cut by laser:* :thumb:
    Come to perfection:* ;)
    Here I have always cut by laser, and bend your machine supports 2:* :D
    And finally here they are arranged and fixed:* :clap:
  18. Gas_designs
    29 Sep 2014
    Hello guys I attach my test done today :clap:
  19. Cheapskate
    13 May 2007
    Looking pretty cool. I can't tell the machine cutting from the hand cutting. :thumb:
  20. Gas_designs
    29 Sep 2014
    Today, after 1,000 tests .... I start to write down and drill housings of the pump ( and also for a possible 2nd ) :D
    ............ :dremel:
