Memory RAM recommendations
Discussion in 'Hardware' started by DarkeningLight, 18 Jul 2013.
  1. DarkeningLight
    DarkeningLight What's a Dremel?
    24 Jul 2010
    Hello Bit-tech,
    Recently my computer has been running slow and looking at the Performance in the Task Manager my Ram is commonly running at between 50% - 65% of max usage. (I have 4GB of RAM). So i thought that i might need a RAM upgrade.
    Firstly would an upgrade in RAM be useful in speeding up my computer. I spend time programming and such but when it comes to hardware i know nothing.
    Secondly if a RAM upgrade would be good could somebody recommend an upgrade and perhaps a guide in how to upgrade.
    I don't know much about my current specs. I recently found out about my DxDiag. Which i posted on my Dropbox. https://www.dropbox.com/s/8o9px7lu2ihzfcp/DxDiag.txt Hopefully it will help.
    Thanks for your help.
    Kieron
  2. Dark Matter
    Dark Matter Minimodder
    12 Mar 2010
    This site has a useful tool which will help you identify what motherboard you have and what memory you need :)
    http://www.crucial.com/uk/
  3. jizwizard
    jizwizard Modder
    24 Dec 2010
  4. mrbungle
    20 Sep 2004
    You would prob find more ram will make bugger all difference tbh if you are not maxing out what you have.
    A ssd however will make things like greased lightening.
  5. narwen
    narwen narwen
    6 Aug 2010
  6. DarkeningLight
    24 Jul 2010
    If i was to get a SSD i would want to change me main drive (C: ) but as far as i know my operating system is installed on it. How could i move the operating system?
  7. sniperdude
    sniperdude Minimodder
    8 Sep 2010
  8. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    +1 on getting an SSD. However, I don't know what a data transfer kits is? I would presume it consists of a SATA data cable and possibly a molex-SATA converter :p
    I wouldn't recommend cloning old HDD to new SSD but it can be done. If you buy a Samsung drive they even give you the software to do it.
  9. adam_bagpuss
    24 Apr 2009
    if you are using 50-65% of RAM then adding more will not do anything.
    If you were using 90%+ id suggest an upgrade but there are better things to do with your money with your utilisation.
    +1 on an SSD like the others you will see an instant performance jump
  10. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    If you get an SSD
    Find your windows installation disc and reinstall. Fresh install will only prevent anything wrong happening and also make it fresh so it starts at its maximum capabillity. Although the speed difference you will notice will be immense
