News Asus announces Haswell-based Chromeboxes
Discussion in 'Article Discussion' started by Gareth Halfacree, 5 Feb 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Might be tempted with a cheap one and see about installing a slim copy of windows on it for a media pc.
  3. faugusztin
    11 Aug 2008
    Windows ? For media PC ? Why ? It would make much more sense to put something like OpenELEC on it - you would fit easily (it uses ~2GB of the dirve), it is a fast booting XBMC install...
  4. damien c
    31 Aug 2010
    True would have to have a look at that stuff.
  5. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    Honestly I can't see this having any better performance than a Raspberry Pi as a media centre - Celeron processor + 2GB ram doesn't exactly have the grunt to do much more than a Pi could.
  6. faugusztin
    11 Aug 2008
    I think you are completely mistaken by the "Celeron" name. It is a low clocked Haswell CPU with a cut down Haswell IGP, which is still more than enough for any media centre tasks. And Pi is completely out of picture, compared to the performance of this CPU and GPU.
    Take a look - http://www.cpubenchmark.net/mid_range_cpus.html - it is between AMD A4-3300 APU and AMD A4-3400 APU in CPU performance, and even if it is has only half of the Haswell GPU, it is still more than enough for HTPC stuff.
    And 2GB RAM... Have you seen actual memory usage of a linux with XBMC on it ? Good luck finding cases when it uses more than half gigabyte of RAM.
  7. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    Pedant time "4GB of DDR3 memory adn a choice of "
  8. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    Oh I'm sure its up to the task I just don't know what it could do that a Pi couldn't as a HTPC? You aren't going to game on it so its really just media playback and the Pi can do 1080p fine in my experience.
    When I compare my (admittedly aging) Nvidia Ion HTPC and my Pi HTPC both running openelec the interface is slightly faster on the Ion but by no means unacceptable on either. Comparing both the only reason I keep the Ion is because it has a DVD drive for those occasions that I might want to play an actual disk.
  9. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
  10. Gareth Halfacree
    4 Dec 2007
    Still getting used to this new keyboard - fixed, ta!
  11. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    This machine though doesn't have the option of a dedicated GPU so as a HTPC (and only as a HTPC) I don't see what it does that a pi doesn't. As a web browser sure its plenty fast enough and assuming this is around the £130 mark its not a terrible price for that. The faster models seem pointless unless you stick Windows on it which would require a bigger SSD which are hard to find in that form factor just now.
  12. GeorgeStorm
    16 Dec 2008
    I thought the pi struggles with large libraries/high bitrate files?
  13. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    I have 300+ movies, 3000+ TV episodes and 257 albums so not a tiny collection and it works fine. Normally I play 720p files but I do sometimes play 1080p which also have always played well for me.
    If you had a mostly 1080p collection I'd probably consider something else - I'm not sure how good this chromebook with its cut down GPU would be though - but otherwise a Pi is more than good enough.
  14. GeorgeStorm
    16 Dec 2008
    Fair enough, I don't personally have one but I thought I remembered hearing it did have issues, maybe now that some of the software used has matured a bit it's got better.
  15. Guest-16
    Guest-16 Guest
    Can't be done, can't access the BIOS. Goog locks it off for ALL Chrome-machines.
    I'm sorry but this is pure crap. Haswell Celeron obliterates a Broadcom ARMv6, even if they were running at the same clock speed.
    ARMv6 (ARM11) does ~0.9 DIPS/MHz
    ARMv8 (Cortex A9) does 2.5 DIPS/MHz
    OLD Atom core (in-order) does 2.5 DIPS/MHz
    Haswell Celeron is not even mobile - it's a full fat Core core.
  16. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    Tell that to my chromebook running Ubuntu.
  17. Guest-16
    Guest-16 Guest
    How'd you get access? They 'should' be locked :p
  18. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Looked at Chromebook for the maternal unit a while - say nine months - ago. Seemed completely unusable. No local storage? Er, okay.
  19. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    All of them as far as I'm aware can be put into developer mode where they can then be booted from usb or SD card. Certainly all the chromebooks that I know of can be and I assume this chromebox will be the same.
  20. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    They do have some local storage, usually 16GB ssd but some have spinning rust. I tend to think of them more as tablets with keyboards rather than traditional computers and in that regard so long as you have internet access they can do a lot.
    For some people they may well be enough to replace a laptop but for others maybe not. Local storage is overrated imho - a server or cloud storage is usually superior.
