Case Mod - In Progress How to make BENCH CASE from an old ATX 1+2
Discussion in 'Project Logs' started by arg-ist, 4 Aug 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    My earlier threads in this forum was 2x CORSAİR 900 D (fulltower)an 800D ,an Level 10 GT,
    TJ O7 and a JUMBO CASE…all fulltowers
    This time a small case and a fast mod at weekend..
    My friend atik wanted a smal bench case ,and not to spend Money.
    only with products ready in the kitchen.
    we used an old cheap atx case
    We planned what to do and what kind of a bench.
    Then we have overthrowed the case
    Emptied the case..
    I had planned watercooling with a 360 rad ,but he wanted to use his 480 XSPC rad.
    480 Rad was greater than the case.and As this was not enough he wanted to use as push-pull and with dobble fan shroud
    I made a front cover to the case for 480 rad.
    .but as an unusual fun shroud. , it was 60(120/2) +120 +120 +60(120/2)
    And he wants the pump and reservoir outside of the case , like 480 Rad.
    I made a tower for reservoir and pump at the side of the case, to use a tube reservoir 250 mm..
    but he used a mini xspc reservoir at beginning.but he promised me to buy a 250 mm.
    And mounted to the case
    But a new request from my frend. He wants to use DWD player and a fan controller at the front..
    A new front cover for dwd player,fan controller and 480 rad..
    I did all wrong requests of my friend…
    We wanted to mount the MB tray on the side door of ATX , and open it with a gas spring arm.
    But the side door of the case was too thin.for a gas spring arm.. ı made a 5 mm thick Alu side cover with 2 hinges.
    [​IMG][/IMG]
    Today frozen cpu and mnpc uses it…on their new experiment case..
    ı used the same gas spring arm on my JUMBO case too.
    To open the upper part of the case.
    OTHER WORKLOGS
    PlayDoh Silverstone TJ07 - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=267324
    SAK SAK 900 D CASE
    http://forums.bit-tech.net/showthread.php?t=271227
    JUMBO CASE
    http://forums.bit-tech.net/showthread.php?t=266554
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    12 Angry Men 900 D Case
    http://forums.bit-tech.net/showthread.php?t=266585
    mmt 900D Case
    http://forums.bit-tech.net/showthread.php?t=266954
    ER36PO Level 10 GT - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
    self made COSMOS II Clear Panel
    http://forums.bit-tech.net/showthread.php?t=277478
    only mini worklogs at hot AUGUST days.. it is better to work at beach
    Greetings from Fethiye /Turkey arg-ist
  2. Cheapskate
    13 May 2007
    :lol: Hey, I know that rig.
    Towers converted to benches seem to be trending, but you have put a lot more care and effort into yours. It should turn out pretty cool.:D
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    And bench was painted black
    My frend uses a lot of HDD s. He needs an HDD cage . ı used side panels of cages and modde it added 2 alu plates and made a great HDD cage. And cooled with a fan
    As MB tray and expansion slots we used the tray of the case.
    For tubing we used some 90 degr. angled clips
    To mount DWD player made a shelf from plexi
    And dwd mounted
    And mounted MB
    And watercooled
    What was wrong at this case:
    Using an 480 rad instead of 360.
    instead an 360 rad mounted at the inside of the case,mounting outside ,
    instead of swiftech micro res… a 250mm reservoir
    ugly glossy black paint
    And working with quite large folds of the hose would it be better like this
    but we must cook with , what we have in the kitchen as ready.
    and spend no Money…
    And my friend was the boss. SORRY.
