News Apple sued over MacBook Pro GPU failures
Discussion in 'Article Discussion' started by Gareth Halfacree, 29 Oct 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Apple had a very similar problem with the 8600M GT (supplier changed substrate solder formulation unexpectedly, leading to thermal stress fractures after many load cycles), and had a warranty extension program for it. Can't think why they wouldn't do the same thing in this case too.
  3. Cei
    Cei pew pew pew
    22 Mar 2008
    Hardly Apple's fault, this one's down to AMD (like the last was NVIDIA). That period of lead solder was bad for GPUs :(
  4. Pete J
    Pete J Employed scum
    28 Sep 2009
    2011 era, huh? So three years - isn't that normal expected life span for computer components?
  5. XXAOSICXX
    XXAOSICXX Minimodder
    20 Apr 2011
    So it's the consumers fault that Apple chose AMD then? Ahhhh, I see!
    And no, Pete J, three years isn't the normal expected life span for computer components. Otherwise you'd be seeing people chucking xboxes and playstations into their bins in droves. I'm still using (alongside my main PC) an 8 year old laptop, a four year old self-build PC, a 10 year old shuttle PC....they all work just as they should, so no, three years isn't "normal"...especially for premium systems/laptops.
  6. MagicBoy
    MagicBoy What's a Dremel?
    26 Jul 2003
    Hardly - it is £1500+ worth of professional grade laptop, not a £300 Acer from a supermarket. UK consumer law tends to agree. My 2006 MBP is still going strong with it's second owner, as it the 2008 MacBook I had after that.
    There were sporadic failures reported in the first couple of years but nothing major. The 2011s then started failing in significant number from 2 years onwards, almost all due to AMD GPU failure. Most exhibit some sort of corruption before it fails completely, I wasn't so lucky - my late 2011 model had a sudden failure in April, so I took it to the Apple Store to get it assessed. They quoted £500 to fit a replacement logic board, which after checking was a refurbished part and only had 90 days warranty on the repair. After discussions with the genius supervisor they agreed to a no cost repair under consumer law. The initial repair failed after less than four weeks, it was then in and out of the Apple Store for the next couple months as replacement logic boards all failed in a similar fashion. Apple have now replaced the Mac.
    The 2011 is a great product, but is fatally flawed. Corporate won't admit there's an issue, hence the class action. I can't fault the customer service from the Apple Store though. Can't much fun trying to keep a straight face whilst denying there's an issue with them.
  7. stonedsurd
    11 Mar 2009
    Damn, I wish I lived in the UK.
    I've already paid once to have my logic board replaced and while I've had no issues since then, I'm sure it's only a matter of time before I'll have to send it in again.
  8. MagicBoy
    26 Jul 2003
    If it fails again it suggest you get it repaired. There's a couple of companies in the UK that will do a board level repair, fitting a new GPU with leaded solder for a fraction of the price of a badly refurbished board from Apple. Feedback from the people that have used them is good so far.
