Case Mod - In Progress Lunar - FINISH
Discussion in 'Project Logs' started by Bouly, 1 May 2014.
  1. Bouly
    Bouly What's a Dremel?
    23 Oct 2008
    Hello everyone,
    After a long absence, I'm back with a new project. :rock: (update 25/05/2015)
    Config:
    ☑ Gigabyte GA-Z87N-WIFI
    ☑ Intel Core i7-4770 3,4 GHz
    ☑ Thermalright AXP-100
    ☑ G.Skill Ares Série 16 Go (2 x 8 Go) DDR3-1866
    ☑ MSI GeForce GTX 760 Gaming ITX
    ☑ Crucial M550 mSATA 256Go with msata to sata Half slim adapter
    ☑ HDD 2,5" WD Blue 1To 16Mo 7 mm
    ☑ Silverstone ST45SF-G 450W SFX
    ☑ Silverstone Tek PP05-E plat flexible
    Accessories:
    ☑ Riser 3M PCI Express X16 L500mm or 250mm
    ☑ Extension HDMI 90° 500mm
    ☑ Dong Bluetooth 4.0
    ☑ Mac white AC power cable
    ☑ Light button.
    Case:
    ☑ Subject usual hijacked : A bathroom bin ( "Authentics Lunar" )
    ☑ Base, air diffuser and holding plates made ​​3D printing
    ☑ Noctua NF-A15 PWM 150mm Fan
    ☑ Structure anodized aluminum profile ("Makerbeam")
    @ Soon for more ...
  2. Impatience
    Impatience Minimodder
    6 Apr 2014
    Seems like this could be an interesting build! Definitely interested in how the GPU will look in the build. :) As for your search, I remember seeing some temperature controlled fans when I was looking online for a case fan.. :idea: It's not one box controlling multiple fans, but they could do the same thing? :clap:
    Oh, and *subbed*! :D
  3. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Your first post of a project log must include some images of work being done otherwise a moderator will move it to the 'modding' section.
    3D printed parts for a case sounds interesting though.
  4. Cheapskate
    13 May 2007
    I came to see what you had because I know you do good work.
    --but there's nothing to see.:waah:
  5. Bouly
    23 Oct 2008
    Hello,
    The mod is not dead, just behind the controls, I expect sales. :D
    Otherwise I'm still in the research phase, I made contact to my laser cutting, drop the price. I turned to 3D printing, and where happiness.
    So I decided to challenge me on this mod, DO NOT DO THAT ASSEMBLY: 3D full study, 95% of parts made in 3D printing and final assembly.
    The only changes to be cut and on the housing.
    Here is a first test of an air diffuser fan Noctua:
  6. Nexxo
    23 Oct 2001
    Dude, it's been over a month. Pics of work in progress or get thee to Modding.
  7. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Have to agree with Nexxo, it's not a log without actual progress pics.
    Take a look at the Aquacomputer Poweradjust 2 Ultra. It's tiny and should do exactly what you need it to do.
    Here is a link to its manual. The product page doesn't do a good job of explaining what it can do.
    www.aquacomputer.de/handbuecher.htm...ds/manuals/poweradjust_2_english_20130524.pdf
  8. Cheapskate
    13 May 2007
    :lol: It's Bouly, so it's still better than most empty logs.
    Intrigued, sir.
  9. Bouly
    23 Oct 2008
    Hello,
    A little news...
    I fell on an article presenting a MOD inspired from Mac Pro 2013 using the "Lunar" dustbin for case, but with a very small configuration.
    Some research later, I discovered an improved version :waah:, powerful configuration, compatible Hackintosh.This version with a few followers, so I followed all these worklogs.
    I decide to make my version, by taking only best installations.
    The first work, modelled 3D the hardware:
    Then to make a first installation:
    To be continued...:naughty:
  10. morgansk
    morgansk I've got wood
    12 Jan 2013
    Ooh, looks intriguing! Subbed!
  11. Bouly
    23 Oct 2008
    Hello,
    Here are some fresh news of my mod.
    The final install :
    The case :
    Modifcation of the case :
    Higher cutting Ø125 and on the side for inputs / outputs rear of the motherboard.
    Disbursement for pasage inside the motherboard.
    Cut the lid.
    Changing the fan by removing the fins :
    Prototyping of hardware installation, small 360° :
    Coupling case/hardware :
    The upper air distributor (3D printing) :
    The base ( 3D printing) :
    In place :
  12. storm-83
    storm-83 Minimodder
    7 Nov 2014
    This is way awesome!
  13. Cheapskate
    13 May 2007
    Finally! :lol: Looks great. See you in 2017.:D
  14. Darkwisdom
    27 Aug 2011
    Looks almost exactly like the recent Mac Pro. That's not a bad thing and I think you've used the donor case very well with minimal wastage. Can't wait to see what happens next.
  15. pekcitron
    pekcitron What's a Dremel?
    19 Apr 2015
    Really good, nice job :clap: ! I had similar idea in my mind and tried few configurations on sketchup ... you are much better than me :D !
  16. Bouly
    23 Oct 2008
    Thank you to all.
    I received and tested my mSATA SSD , too well ...
    Comparison between a hard disk 3.5 " 320GB SATA / SSD 2.5" 256GB / 256GB mSATA SSD and with adapter :
    A final test operation of all:
    To be continued... :naughty:
  17. Cown
    Cown Minimodder
    25 Feb 2012
    Nice concept :D Looking forward to seeing more :)
  18. Bouly
    23 Oct 2008
    After 16 months of research and study, the mod is over. :wallbash:
    The config : :thumb:
    ☑ G.Skill Ares Série 16 Go (2 x 8 Go) de mémoire DDR3-1866
    ☑ Riser 3M PCI Express X16 L250mm
    ☑ Noctua NF-A15 PWM Fan 150mm
    ☑ Light button
    ☑ White Power Mac power cord
    The case : :thumb:
    ☑ A bathroom trash ''Authentics Lunar''
    ☑ Base, upper air diffuser, keeping Plates, motherboard support and SSD 3D printing
    ☑ Black anodized aluminum profile structure ‘'Makerbeam''
    Mounting : :dremel:
    Support for the start button and the HDMI cord.
    The power supply.
    The lower support.
    A part of structure.
    PCI riser (after a full afternoon to bend), graphics card and power of it.
    The motherboard support.
    The Motherboard with the wiring.
    Extension HDMI.
    The motherboard equiped.
    The mSATA drive and bracket.
    The upper support.
    The fan.
    The upper air diffuser.
    A small 360° with hard drive:
    [​IMG][​IMG]
    [​IMG][​IMG]
    The case, the carrier and the closing ring.
    The motherboard Cache (two working days).
    The lower ring.
    The closing.
    Le case.
    The cache up.
    On the way ………. :rock:
  19. Fable
    Fable What's a Dremel?
    18 Mar 2014
    Too top top! Are you going to do some graphics on the case?
  20. Cheapskate
    13 May 2007
    That was an insanely slow, but satisfying finale.
