News Silverstone shows off massive TJ12 concept case
Discussion in 'Article Discussion' started by arcticstoat, 6 Jun 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Jipa
    5 Feb 2004
    Just the thing for all of us with six graphic cards!
    Wait... wat?
  3. Zurechial
    Zurechial Elitist
    21 Mar 2007
    I already like the aesthetics of it and it looks to have plenty of surface-space for radiators (which matters more to me than space to accomodate an SR2 or a folding farm's worth of graphics cards).
    It's just a shame that, knowing Silverstone, it's likely to very well-made but incredibly expensive.
  4. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    1p - talking point, not consumer focussed... When you think there's so much more they could have showed as a concept other than a big box - poor showing. Two 3 x 120 rads in the base? So where does the airflow go - up or down?
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    For all you crazy folders out there!
  6. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I would imagine up by default, unless you flip the fans. However the FT02 showed that the flow system in use is really good... For air cooling at least.
  7. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Ol' Mac Donald had a folding farm, E-I-E-I-O.
    And on that farm he had some GTX 580s, E-I-E-I-O!
  8. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    Looks like an ideal case where a home user could mine some bitcoins on 6 AMD cards.
  9. Parge
    16 Jul 2010
    If I was rich I'd buy an atom board and put it in this for comedy value.
    Zurechial and lilgoth89 like this.
  10. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Only one exhaust fan on the top, but two intakes below the graphics cards. What's supposed to happen to all the hot air?
  11. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    ^^^ HAHAH rep to you sir (parge)
    i know this is a concept...but i really...really want one...
    not that it would fit on my desk, nor do i have a system that would half fill it...
    but it looks AWESOME!!
    i hope they put some 3.5in bays in, and some optical drive bays would be nice to :)
  12. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    Not only for folders! You can put HDD modules instead of VGAs for "mega-uber-storage-whoring" system.
  13. Phalanx
    28 Apr 2010
    It works. The FT02 has the same setup. The pressure inside the case keeps it moving perfectly fine.
  14. matee
    matee What's a Dremel?
    12 Feb 2003
    Will it play Crysis 3?
  15. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    Six dual-slot GPUs with room in between each and only 2.5" drive mounts? What this case would be effing amazing for is a high-powered folding rig.
    The only problem I see is the lack of a second PSU mount in stock configuration. Right now you're forced to choose between one PSU and up to six GPUs (not enough power if you get higher-end GPUs) or two PSUs and four GPUs (unnecessary you could power four higher-end GPUs with only one higher-end PSU if you wanted to). Putting two PSU mounts side by side would fix this potential problem, and I think could be done without altering the height of this particular case.
    Looks awesome, though. If I was ever building a folding rig, this case would be at the top of my list. :thumb:
    - Diosjenin -
  16. CashMoney
    CashMoney What's a Dremel?
    14 Jul 2010
    I'm I the only one wondering why a this behemoth of a case, running an awesome 6 graphics cards, no doubt for some huge monster graphics .... is using a DVI to VGA adapter?!?
  17. thom804
    thom804 Minimodder
    22 Oct 2009
    Can you say the first "mass market £1000 case"?
    It's probably not the first, but if it does make it to production, by god will it be expensive!
  18. thom804
    thom804 Minimodder
    22 Oct 2009
    With a whoosh whoosh here and a whoosh whoosh there,
    Here a whoosh there... wh...eve.. oosh whoosh.
    Hang on, I can't even sing the song in my head just thinking about the noise this'll produce!
  19. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    This is completely impractical for my use, but i wants it anyway!
  20. Stotherd-001
    Stotherd-001 Minimodder
    15 Apr 2009
    No. All that power.... going to VGA. Thats just wasteful. I'm guessing the cards are dedicated to farming rather than actual graphics though.
Tags: Add Tags
