USB Speakers
Discussion in 'CCL Computers' started by Matt39, 6 Jan 2013.
  1. Matt39
    Matt39 What's a Dremel?
    9 Oct 2012
    I wanted to know if i could plug USB speakers into the side of my monitor which has 2 USB slots. the jack socket is broken. my monitor has hdmi so is being used has a tv by hooking it up to my sky box. The computer isn`t connected to my monitor when its hooked up to sky box. Any help would be appreciated.
  2. Dan @ CCL
    Dan @ CCL What's a Dremel?
    24 Dec 2011
    Hi,
    Should probably work for the computer audio, as the USB ports on the monitor will act like a hub, however it wouldn't output the HDMI audio and you'd need to change your default audio device in Windows. It wouldn't work for the Sky box though unfortunately.
