RAM Swappings
Discussion in 'bit-tech Folding Team' started by enigmo, 21 Dec 2011.
  1. enigmo
    enigmo Kettleboiler Extraordinaire
    13 Apr 2010
    Quick question; if I have two machines that are otherwise identical (both i5 760 based machines), but one has 12GB RAM and the other has 4, would I get an overall PPD bump if I moved some RAM so both have 8GB? The 760 is a quad core chip so that would give all cores 2GB RAM each to play with, which I /think/ is the current bigadv rule.
  2. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    I can't see there being much change.
    I've found that BIGADV units don't use more than a couple of Gig in total. try checking out the resources being used while you're running the BIGADV's....
  3. enigmo
    13 Apr 2010
    On the topic of bigadv units, do I need to switch off advance methods in the config to get them? I never seem to get anything other than A3 units even though my extraparms are -bigadv -smp -verbosity 9
  4. RedFlames
    23 Apr 2009
    Bigadv [and bigbeta] units require 12 threads [soon to be 16] so you won't get any as the 760 only present 4 threads each
  5. enigmo
    13 Apr 2010
    Did it used to be 8? I was hoping I could get my 2600k on some of them, but it seems not :(
  6. enigmo
    13 Apr 2010
    I had another bit of a look around, and I don't know where I got 2GB per core from, but it appears that 0.75GB per core is the recommended amount.
    Ta all, anyway
  7. Tattysnuc
    19 Jul 2009
    BIGADV requirement was 8. I've not seen anything upping to 12....
  8. RedFlames
    23 Apr 2009
    I'm sure the requirement for some [but maybe not all] bigadv/bigbeta WUs was upped to 12, hence a lot of people going for 970s and above
  9. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
  10. Tattysnuc
    19 Jul 2009
