News Microsoft details Windows 10 space savings
Discussion in 'Article Discussion' started by Gareth Halfacree, 17 Mar 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    Aw I was hoping they'd have done something about the excessively huge winsxs folder (or whatever it's called). Seems to me re-using existing system files for system recovery is a TERRIBLE idea though. A very probable reason for wanting to do a full system recovery is because the system files are corrupt in some way (either by disk damage or viruses).
    However, I am in favor of compressing the system files. I do that now. On modern hardware it only improves performance, while saving disk space. I don't think it should be enabled on phones though. I'm not sure how big the Windows Phone OS is but I haven't heard anyone complain about its size. CPU and RAM though, those are much more limiting resources on phones, so I really don't think compression is a good idea for phones.
  3. Gareth Halfacree
    4 Dec 2007
    Oh, there have been plenty of complaints about the amount of space Windows takes up on tablets and smartphones - remember when Microsoft got hit with a lawsuit over the available space on the Surface tablet family?
    As for compression, I disagree that it should have a major impact on smartphones. LZNT1 was designed to be near-as-dammnit invisible back when having a single-core Pentium II 233MHz made you hot stuff; these days, even the cheap-end smartphones have a 1GHz dual-core processor and a chunk of RAM. More importantly, many low-end models will be more burdened with slow flash access than a lack of processing power - meaning that compressing the system files will improve performance (as less data needs to be loaded from the slow flash) compared to leaving them uncompressed - theoretically, at least.
    Basically, as far as I'm concerned, inline compression stopped being a 'why' when dual-core processors became a thing; now it's a 'why not?' My server and desktop both use a compressed Btrfs array for data storage (zlib on the desktop, LZO on the relatively underpowered server) and I've enabled LZNT1 compression on the entire system drive on my Atom-based Windows 8.1 tablet.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    The winsxs folder isn't actually that large it's just explorer doesn't account for hard links so a single file gets counted twice when calculating how much space it's taking up.
    A virus or corruption preventing a full system recovery can be said of the current recovery partition only with a hidden recovery partition it's much harder to address the problem due to it being hidden.
    Re-using existing system files for system recovery seems a much better way of doing things to me as you won't need to re-apply any updates and even though I'm not sure how Windows keeps track of system file integrity when using SFC /scannow wouldn't they use a similar technique to reduce the chance of system files becoming corrupted/infected?
    If things go really wrong you can always use the manually create recovery media.
  5. David
    7 Apr 2009
    I need to look into how to do that, and try it out on one of mine.
  6. Gareth Halfacree
    4 Dec 2007
    Right-click on drive (or, as it was a tablet, long-press on drive) and choose Properties. Then click 'Compress.' Tell it to apply it to existing files and folders. Wait a reasonable length of time. Dismiss errors about files in-use that it can't compress (like the swapfile). Dun!
    (You can also choose to compress specific sub-folders instead, by right-clicking on them, or even individual files. Neat, innit?)
    David likes this.
  7. RedFlames
    23 Apr 2009
    Need to point out some programs [admittedly probably nothing you'd be running on a tablet], spaz out royally if NTFS compression is turned on...
  8. schmidtbag
    30 Jul 2010
    I remember that used to be a problem but I'm not really sure that applies anymore. If MS intends to compress the entire drive, I can't imagine it's still an issue.
    @Corky42
    Correct me if I'm wrong, but I thought the design was so software links their libraries to the winsxs folder, not the other way around. That being said, there shouldn't be many links inside winsxs. Either way - the folder comes with far more libraries than it needs to. I'd rather just have the libraries I actually need installed, not just a random collection of "here's a few thousand things you might need, but there's a good chance this isn't sufficient".
  9. RedFlames
    23 Apr 2009
    IIRC the only one that i recall having major problems now say 'turn it off' or turn it off for their files... the problem comes if you turn it on *after* the program is installed...
  10. David
    7 Apr 2009
    Damn, that's a damned sight easier than I was expecting. I was readying myself for a pony trek into the deepest recesses of the registry.
  11. XXAOSICXX
    XXAOSICXX Minimodder
    20 Apr 2011
    My £99 HP Stream 7 tablet (bought for the free Office 365 subscription and 1TB of OneDrive space bundled with it) runs 8.1 on very tight hardware and still performs admirably thanks to WIMBoot, and I personally find it to be excellent.
    I think Microsoft get a lot of stick for much of what happened in the past, understandably so, but they're really making some good moves now (that Ballmer is gone)...and this is one of them. My Lumia 930 outperforms every phone in the office at work, the Surface Pro is now a cracking piece of kit, and Windows 10 is looking awesome.
  12. schmidtbag
    30 Jul 2010
    Shhh.... last time I stated that people started arguing. The funny thing is Ubuntu is considered bloated, for linux.
  13. Corky42
    30 Oct 2012
    You would think (me to) that how you describe it working is how it works, but going on info from here it's the other way around.
    EDIT: Then again from what I'm reading here it works as you describe, talk about confusing. :confused:
  14. schmidtbag
    30 Jul 2010
    I agree, but isn't Windows Server a lot like that? I never directly used a Windows Server setup on a PC so I don't really know.
    For the extreme minimalist, there's Windows PE (or whatever it's called now).
  15. David
    7 Apr 2009
    I tried it out on my Linx 10. It took a couple of hours or so, which used surprisingly little battery, and I don't notice any slowdowns - it's just as snappy as before. :)
    BTW, has anyone run ATTO SSD benchmarks on these? I don't know if the compression affects it but the read scores were off the chart. Write speeds were more believable in the 200-250MB/s range - similar to a SATA2 SSD - but I was getting 1300+ megabytes per second reads. :jawdrop: :confused:
  16. schmidtbag
    30 Jul 2010
    I guess it is possible - if your normal maximum read speed is 250MB/s but you have a 1.3GB file compressed into less than 250MB, then your CPU and RAM is handling most of the load.
    I've done an experiment where I tried running a game off of a DVD. In once instance I left the files in-tact, accounting for roughly 2.5GB of data. In another instance I put the game in a squashFS archive, shrinking the contents to about 350MB. It could take up to 2 minutes to load a level with the non-compressed files, but it took maybe 20 seconds to read from squashFS. Note that it isn't just the compressed data that makes loading faster. For mechanical storages, like DVDs or hard drives, the seek time dramatically decreases because the file contents are more concentrated. Seek time is the primary reason why HDDs are so slow. When doing sequential reads, both mediums have very modest performance.
  17. David
    7 Apr 2009
    I'm going to run the same benchmark on the Linx 7, as I haven't compressed that one yet.
  18. nimbu
    nimbu Multimodder
    28 Nov 2002
    Wondering if when you install windows, drop down to a cmd prompt and create the required partitions as compressed to begin with.
    Would that work?
