Hardware Turtle Beach Ear Force Stealth 450 Review
Discussion in 'Article Discussion' started by Combatus, 17 Sep 2015.
  1. Combatus
    16 Feb 2009
  2. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Thank you for the review Mr. Lambert.
    Maybe I have missed it but how loud or annoying is the white noise on these headphones?
    Every wireless headphone but the very high end ones from Sennheiser I have tried so far had some low humming noise due to the wireless transmission that absolutely drived me nuts.
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    No worries :) it is there, but only if you *really* listen for it when there's nothing playing, and only in the right earcup it seems. It never bothered me but if you're particularly sensitive to it I guess it could.
    Aterius Gmork likes this.
  4. Aterius Gmork
    25 Sep 2007
    Thank you! Having the noise in only one earcup sounds even worse than having it in both so you just saved me the hassle of ordering and then returning another pair of headphones.
    I listen to quite a bit of spoken audio as well as movies or games. The background noise on my last pair of wireless headphones really drove me nuts after a while. I found myself paying more attention to the background noise than the actual audiobook I was listening to. Probably I'm just a sensitive wuss.
  5. Dogbert666
    17 Jan 2010
    No worries. It is more noticeable with spoken audio actually - I'll have to start listening to podcasts when testing headphones as well!
  6. XXAOSICXX
    XXAOSICXX Minimodder
    20 Apr 2011
    I remember back when Turtle Beach made ISA sound cards that no-one could afford, leaving us all selecting Soundblaster 16/Pro compatible and dreaming of what a "proper" sound card might sound like....
    This headset, on the other hand, certainly isn't going to make me put my Qpads in the closet.
  7. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I know it's a really silly reason but I wouldn't even look at them purely because of their name containing 'Ear Force'.
Tags: Add Tags
