I am currently building a desk mod, i will have 3 reservoir installed horizontally at the center of the desk while motherboard and hard drives will be installed on the side. The water pumps will be connected directly at the outlet of the reservoirs. I am now thinking that there will be permanently some air in my reservoir (being the high point and considering i will be connected on the sides of the reservoir) that will impact the amount of water available at the suction of the pump. If you have experience installing reservoir horizontally, did you suffer from trapped air in reservoir? did it impact flow/reliability of the pump? Would you share any tips and tricks how to properly install these reservoirs (any special reservoirs?)? thanks for your advice.
