Case Mod - In Progress Project: PlayStation 1 PC
Discussion in 'Project Logs' started by ElectrixPC, 3 Dec 2011.
  1. ElectrixPC
    ElectrixPC What's a Dremel?
    20 Nov 2011
    I had an idea a few months ago to put a PC inside a PlayStation 1 (The original one). i figured that you could do a little bit more than just put some components in it and turn it on.
    My ideas are:
    -Make the On/Off switch fully functioning
    -Make the Reset switch work
    -Have a fully working DVD/RW drive where the original CD-R drive was
    -Use original game controllers when gaming.
    I thought about going down the line of Mini ITX, but i thought the advantages of using it were were not good as using other forms.
    So what im going to use is the Motherboard from a ACER Aspire ZG5, it is a 8.9" netbook, having an Atom N270 in it. Admittedly, it inst going to be an SR-2 with capabilities of restarting planets, but it will be sufficient for the HTPC that i plan.
    Using the ZG5 Motherboard does have its advantages, for instance, the power supply is external so that saves space, it can be run on its battery which can last up to 9 hours! and the motherboard itself isn't a big unit, so it will happily fit inside this blast from the past.
    Anyway, on with the Mod.
    I had originally planned for one of my friends to give me his one, but that had 'vanished' into thin air.
    So i jumped onto eBay and bought one, and it came this morning!
    I jumped into disassembling it, and here is the pictures..
    The original PlayStation 1, haven't you all missed it?
    Underneath view:
    Top case off:
    Metal sheet and CD-R drive off:
    Motherboard out and everything laid out:
    Close up of bottom case:
    Controller block out:
    A lot of pictures, one of the many advantages of loving photography :D
    Ill post back when i recieve something else, but its going well so far. :rock:
  2. McDuff32
    McDuff32 Minimodder
    5 Aug 2011
    Ewww dirty case :D
    Interesting project!
  3. Sutura
    Sutura What's a Dremel?
    23 May 2011
    Nice, that is a cool idea. Hope you do it, as best as you can. I still don't quite understand the reasons to go for a netbook MB, instead of an MiniITX, though. Perhaps the size is the primary concern? And this: "-Use original game controllers when gaming." seem to me as the hardest part of the plan. I can't wait to see what happens next. Mod on!
  4. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I agree, it's a great idea! :) I still have mine in a closet somewhere... Wanna make one for me while you're at it? :lol:
  5. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Well said :D
    Good luck!
  6. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Will you play tomba on it ??? :D!
  7. ElectrixPC
    20 Nov 2011
    I think ill clean the case in a bit, it did look pretty awful..
    Although i seem to remember that when i was younger i had another one which had a drink spilt on it! :D
    Ill build this one, and get it running, i might build a couple of others if people asked really nicely ;)
    Oh, and 'Sutura', you can get an adaptor for the PS1 controllers to go to usb, so it isnt as difficult as once seemed!
    I think the first game ill play is Gran Turismo, god i used to love that game!
    Ill post back with a couple of pictures once i have cleaned it :D
  8. ElectrixPC
    20 Nov 2011
    Okay, here is the pictures from the cleaning endeavours..
    I think it came up really well,
    Anyway, what we all want to see! Pictures!
    Here is the inside of it, nice and sparkly..
    This is the outside of the case, that was a bit dirty as well, - Note, i forgot to put the controller block back in..
    The underneath of the top part of the case, this wasn't really dirty, but i didn't take a picture of it last time!
    This is the other side of top half, with the CD lid open, nice and clean! :D
    Not too sure what ill get next, maybe the Motherboard?
    Talk to you all in a bit----- ;)
  9. ElectrixPC
    20 Nov 2011
    Bit more of an update on how im going to use the PS1 controllers, and a couple of other things..
    I thought id pull apart the back PCB and see what was behind it and see how much modding is needed!
    After removing it, (And nearly slicing my thumb off with a screwdriver) it looked like this:
    So, what ive bought is an adaptor from PS1 to USB and i am going to take it apart and put the pins in the holes above..
    Doing this would mean that the controller block will be unchanged from the front and would plug right in.
    I thought then, what about the Memory Card slot..
    MAYBE USB'S!
    So when i get round to buying my dremel, ill cut holes in the back of the controller block and put some USB's in it. i think that would look good and be functional!
    I want to keep the original door in, so the USB slot's will be set fairly far back in the block.
    Its a bit of a tight fit for them to go in, so i think i might have to sand the bottom down a little to accommodate them.
    Here's a view with the usb's in when the case is together..
    Ill post back when i recieve the USB hub and the adaptor. :p
  10. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Really LOVE this idea
    Sub'd
  11. ElectrixPC
    20 Nov 2011
    Okay, so a little update..
    The Motherboard is bought, and im in the process of buying my Dremel multi tool.
    The usb hub came today aswell, so here is a picture of it for no reason! :D
    Ill post back when i recieve the Motherboard, with a few pictures!
    I think ill maybe do an ITX version once i have finished this, so im seeking sponsorship ;)
  12. Mojo
    Mojo Multimodder
    18 Nov 2011
    Ello mate.. just a heads up; found a controller to usb connector in maplin today and thought of you!
  13. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Hey I saw this on OC3D :). Really good idea mate, looking forward to the outcome.
  14. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    oooo this will be good :)
    Question is, will you put the PS1 components into something else? ;)
  15. jamsand
    jamsand Minimodder
    21 May 2011
    ^ epic idea!
  16. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    loving this great mod so far chum, I'm subbed :D
  17. ElectrixPC
    20 Nov 2011
    Well,
    We have a big update!
    The Motherboard is here, and much smaller than i originally thought.. :D
    Here's a view with it inside the PlayStation, just as a size comparison..
    its surprising how close the actual motherboard is to the size of the board that was originally in the PlayStation!
    But hold on, whats this?!
    Yup. the Dremel came!
    Anyway, i got to grips with it and went to my tool bench and removed all of the plastic bits and bobs that were holding the old boards in, and it came out like this..
    Not a perfect job, but its fairly smooth.
    Here's the motherboard in it after removing all the stuff inside, i think i want it to sit like this..
    Something else came today, the PS1 to USB adaptor, so all i have to do now is work out how to remove its plastic casing!
    I sense the dremel may have something to do with it, i think ill wait until later and wake everyone up in the house ;)
    Anyway, im not too sure what will appear next in the wonderful british royal mail (sarcasm). God the're rubbish! D:
  18. Mojo
    Mojo Multimodder
    18 Nov 2011
    loving the ideas so far :)
  19. yassarikhan786
    10 Aug 2011
    ^^As above. Can't wait to see what you do next!!!
  20. OmightyOne
    OmightyOne Minimodder
    7 Nov 2011
    looking good, good idea for the usb ports, keep it up :)
