News Intel releases 48-core processor
Discussion in 'Article Discussion' started by CardJoe, 8 Apr 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    How long until some madman puts one in a regular PC?
  3. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    of course, those who need 48 physical processing cores in a workstation right now can go off an build an AMD magny-cours system. Ok so that's going to be a multi-CPU machine, but that's the price you pay for massive scalability, damnit!
  4. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    Well it's all very interesting but as to whether or not we'll see these in home PCs I'm not really sure. I don't see the need unless home computing takes a major step in some direction or other.
    48 core won't be much use to the average internet surfer. Maybe the technology will help with the production of very low energy single and dual core models that will pop up in all sorts of embedded applications?
  5. scawp
    scawp What's a Dremel?
    8 Sep 2009
    Will it run crysis on high settings?
  6. livenoise
    livenoise Virgin Modstar
    22 May 2009
    But can it run Crysis?
  7. yuusou
    yuusou Multimodder
    5 Nov 2006
    Can you play Kirby Fun Pack 8 in 1 on it?!
  8. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    Depends how long it takes for Intel to ship one to me :)
  9. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Quick question - What are all of the leads (black and red) going into the motherboard on each side of the cpu socket?
  10. Fod
    26 Aug 2004
    they deliver the magic smoke to the CPU for it to work. Because it's a prototype they haven't finalised the way the smoke is held permanently inside the CPU package, so it's always letting magic smoke out, therefore requiring a constant fresh supply in order to continue operating.
    dark_avenger likes this.
  11. confusis
    confusis Kiwi-modder
    5 Jan 2006
    How about a folding rig?
  12. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    How about properly multithreaded general applications?
  13. Xir
    Xir Modder
    26 Apr 2006
    +1
    Have you never noticed how in EVERY SciFi setting, everything always smokes?
    Star Trek-Star Wars-Stargate...as soon as someone hits a console with a kids toy gun, the things smokes and explodes.
    (I'd always thought it was steam, but nobody's ever burnt, just blastwounds...so it must be smoke...Smoke's the future!)
  14. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    The question is; will it run paint?
  15. borandi
    borandi What's a Dremel?
    27 Jan 2010
    The Cell almost had it good. A few fast cores, then a ton of slower cores.
    Think about it, that's almost identical to the CPU/GPU setup - quad core + 1600 shaders is 4 powerful cores and 1600 smaller, slower cores.
    If the 48 cores are all x86/64-bit compatible though with reasonable logic, that's the middle ground. Expect to see workstations with a quad/hex/octo core and then 4/8 of these chips inside.
  16. Guest-44432
    Guest-44432 Guest
    The question is will if run Dos? ha ha.
  17. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    can i become an academy so i can get one?
  18. cgthomas
    20 Oct 2009
    I can be in your academy
  19. javaman
    javaman May irritate Eyes
    10 May 2009
    Does it support hyperthreading?
    read recently they they've managed to multi thread word.
  20. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    Sound like it will only be strong in massively threaded applications or large numbers of applications, and incredibly weak for applications that are lightly threaded, such as games. Plus, the cores are probably quite simple given the die and socket constraints, so the cores are probably weaker than even Atom cores despite the similar clocks. The only advantage is there are lots of them. And I don't see any mention of the core being x86-based, so they may not support those instructions.
    That sounds like AMD's Fusion/Llano.
Tags: Add Tags
