Hardware Open source alternatives to Windows Home Server
Discussion in 'Article Discussion' started by brumgrunt, 19 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    On backup: I recommend something like CrashPlan instead, if you can install it for your chosen server. It has installers for Linux and Solaris, but not FreeBSD last time I checked; I run the Solaris version on Nexenta.
    The advantage it has is that, when running on your PCs, it can back up to multiple destinations; I have mine configured to back up to both my Nexenta NAS and the cloud. So I get off-site backups as well as very high speed restores.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    There is one thing blatantly missing from this article - backing up your home server!
    (In before Pookeyhead...)
    All well and good putting your important files, backups and media on a home server, but if you don't backup the server, you are just moving the single point of failure from your PC to the home server.
    Personally I use two...a Synology DS211j which backs up to a home built NAS via rsync (OpenMediaVault but used to use FreeNAS). The network backup options in Synology's DSM allows versioning and there are probably similar options available in the open source packages mentioned in the article.
    You don't need another server to backup your home server, an external hard drive will do, but you must back it up or suffer the consequences.
  4. Anakha
    Anakha Minimodder
    6 Sep 2002
    For streaming, I have to say that you've really missed out on the best DLNA server out there, bar none.
    Serviio is written in Java (but it's not that bad, honest), and supports most (if not all) streaming clients out there. It has built-in content recognition to sort your music, TV and movies correctly, including displaying covers and other fun DLNA features like resuming playback. But that's not the best part. It also has a built-in live transcoding system. So if you have a AVC High/AAC 7.1 video file, but your streaming box (TV, Xbox 360, HTiB, whatever you're connected to) doesn't support the format, Serviio will automatically transcode the file on-the-fly into a format that IS supported by your device. AppleTV won't play FLAC? Not a problem! X360 won't play VOB? Big deal!
    Oh yeah, and thanks to the power of plugins and scripting, it'll also play streams from BBC's iPlayer (if you're in the UK), Youtube, and many many more. And while the DLNA service might be built in Java, all the transcoding and streaming is handled using FFMpeg, so it'll stay up to date and use all the features of your CPU.
    Combine it with Transmission running in Daemon mode, and FlexGet to grab TV/Radio/Movies from RSS feeds, and you'll have no need of your TiVO anymore.
    I'm running the above on a basic Ubuntu server in the basement (though it needs upgrading since I switched to HD), and while the interface for adding/changing hard-drives is very unintuitive (okay, it's LVM on the command-line) it's something that needs to be done so rarely it's a "set it and forget it" thing. One mountpoint exported over SMB, LVM handles the RAID (well, JBODing, but who's checking?) and you're set. Throw in an Apache install (just 'cause. It's not really needed at all) and you're set.
  5. Gareth Halfacree
    4 Dec 2007
    I'd disagree: if you're using your server as a backup server for client PCs, then there's no real need to backup the backup (aside from a desire to take a belt-and-braces approach.) You'd only need the backup if the client failed, and the chance of the client failing at the same time as the server (in a way that wouldn't also take out the backup server's backup server, such as a fire or massive electrical surge) is minimal. If you want to truly protect yourself, you'd want to combine a single on-site backup with an off-site backup. Having two on-site backups isn't the protection you'd expect...
    If you mean backing up content that is *only* on the server - and not duplicated on client PCs - then you're quite right, that's something you need to do; I'd argue that's outside the scope of the article, which is simply looking at how to replace the most commonly-used features of Windows Home Server with open source equivalents.
    I could be wrong - I haven't used Serviio myself - but most Java-based transcoding-capable media streamers require X and a desktop environment to be installed - something I, personally, try to avoid on a server. (For the record, I use an ARM build of miniDLNA on a server which wouldn't be capable of real-time transcoding anyway, which is one of the reasons I haven't looked into that side of things since I ditched Windows and the excellent TVersity.)
  6. faugusztin
    11 Aug 2008
    And for drive pooling, you can use Greyhole. There is a OpenMediaVault plugin (my experience was that some features worked and some were buggy in the UI) and it is already included in Amahi. That is if you need web GUI for pool configuration. If not, you can use any Linux distro.
  7. Fingers66
    30 Apr 2010
    ^ This scenario is what I was referring to and you are probably right about it stretching the scope of the article although a health warning is still applicable.
    With regard to important files, you are correct but I would of thought that when streaming media from the home server, would people keep the media on the PC, back it up to a home server then stream from the backup? Surely the inference is that the media is solely kept on the home server?
  8. Gareth Halfacree
    4 Dec 2007
    Very true - but remember, the article is just about replacing Windows Home Server features with open source equivalents. If they didn't have a backup of their Windows Home Server, then they're in the same boat when they switch to VortexBox (or whatever; ) if they did, then they can use the same backup with their shiny new Linux/FreeBSD/whatever server.
    Now, if people would like to see a feature on backup best-practice, that's a whole new ballgame - and something I'd be happy to cover if there's a demand!
  9. asura
    asura jack of all trades
    22 Apr 2009
    Please.
  10. Fingers66
    30 Apr 2010
    An article on backup best practice would be great, if only to stop Pookeyhead ranting in the forum that "RAID is not backup", it might save his keyboard...
    :D:D:D
  11. Harlequin
    Harlequin Modder
    4 Jun 2004
    thank you
    i shall be using this - for setting up a home file server later on today !
  12. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    Used FreeNAS back in the day then tried OpenMediaVault when it got released. Both superb but didn't give me the flexibility I needed. Luckily I've built up my Linux skills over the last few years to a fairly capable level so now use Ubuntu Server and Webmin for lights out management.
    Backup my PC and the wifes laptop with RSYNC, Transmission handles the downloads and Plex Media Server installed on it for streaming media to my Android tablet and an Android 4 based TV set top box.
    Great article though. Loving the inclusion of this kind of thing in Bit-Tech.
  13. mi1ez
    mi1ez Modder
    11 Jun 2009
    Great article. I'm about to get my hands on a couple of old PCs and might take a llook at turning one into a fileserver. Oh, and another yes to a backup article!
  14. Risky
    Risky Modder
    10 Sep 2001
    I'm still running a WHS1 Box - It's not perfect, remote access isn't working and I have had to run some disk checks once or twice but it's been goign for a feew years and does the critical stuff (backup and filesharing) fine.
    I'll replace it at some point but it has to be the last place I want to start trying things out.
    For the record it is running on a HP Proliant ML110 G4 with some critical folders getting a cloudy backup from keepvault.
  15. neocleous
    neocleous Minimodder
    12 Feb 2002
    Thanks for writing the guide, but each distro seams to be good at one specific thing where as Windows Home Server seems to do them all pretty well.
    Also I would imagine that installing any of these operating systems would involve formatting my WHS software RAID drives which I don't think is possible any more for me as I have too much data now
  16. Gareth Halfacree
    4 Dec 2007
    There is that, but the individual sections were picked specifically for people who use one feature more than another. It's possible, for example, to install a UPnP media streaming server on FreeNAS, if you need both a file and a media server; it's also possible to go the opposite way, and store your data - and backups - on an OpenMediaVault server alongside your media. Nagios, and similar, can also be installed on any server in addition to any other tasks it might carry out. All these options do, however, require a bit of work - some more than others.
    That, right there, is the big problem. As you say, WHS fake-RAID drives are pretty much impossible to get working on any non-Windows OS. You'd need to back up the data first, or build a second server with one of the suggested distributions on it, copy the data from the old server across the network, then retire the old server.
    'Course, if you don't have any backups of the data on the server now, you're risking a lot: RAID improves availability, but it's not a backup. If the WHS box dies on its backside, or decides - through glitch or malware - to wipe all your data, or there's a power surge that kills both hard drives... Bye-bye, data.
  17. faugusztin
    11 Aug 2008
    That is pretty much what am i doing right now. I got fed up with WHS2011 inside ESXi giving me ocassional pauses in the DVB stream, Drivebender sometimes switching to read-only mode because WHS hammered it with the backup system etc. So after a bit of looking around i replaced ESXi with Ubuntu 12.04, installed Amahi on top of it (solves the DHCP, Samba shares and drive pooling part of equation), manually installed lates vanilla kernel + DVB drivers + MythTV and later i will add all the remaining services i need.
    I was thinking about OpenMediaVault, but being based on Debian means it still uses archaic 2.6.x kernel which is unfortunately issue for the drivers for my DVB-C card, plus the Greyhole plugin was buggy. So i choose Ubuntu + Amahi.
    Now only i have to manually move all the data drive by drive (mount ntfs drive, copy data to the pool, unmount the drive, delete ntfs partition, create ext4 partition, format ext4 partition, add drive to Amahi, add drive to greyhole pool, repeat) :D.
  18. GeorgeStorm
    16 Dec 2008
    I would also be interested in a backup article, something I still need to get around to doing...
  19. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Excellent to see more material that I'm interested in coming onto the site Gareth. I've an old machine from work that's found it's way home that I'm looking to re-purpose as a file server, and move my raid card into there. It'd be nice if you were to do a how to in the same light that you (or your colleagues - I'm not sure without checking) have done with the scratch build PC.
    Thanks for feeding my home-geeking. :)
  20. VDPloeg
    VDPloeg What's a Dremel?
    1 Sep 2009
    I'm surprised Amahi didn't make it into the article, as it's the closest to a complete WHS open source replacement.
    I'm not terribly knowledgeable with Linux but would love to see a how-to about putting together a complete WHS open source competitor.
Tags: Add Tags
